Variations in graphic scales
603
10-11-2025 12:07 PM
CT_GIS
See below the scales created for two maps.
Why do they generate with slightly different scale bars?
Also, checking the ratios of length in CM / miles does not yield the same ratio between maps (2.4886/45 is not close to 2.4996/55)
It would therefore be inaccurate to use the same graphic scale bar on both maps, right?
I am extremely appreciative of any assistance from the Esri team and community.
CT_GIS
another example comparing graphic scales from two maps at a higher detail.
