'My Organization' Folders Have No Maps
1790
11
06-06-2017 08:36 AM
BriannaEaton
Hi! I just installed the Creative Cloud Add-On (super excited about this release!). Once I logged in and made the map extent, I tried to add layers from 'My Organization' unsuccessfully. I can see the appropriate folders within 'My Organization', however all of my folders are empty.
In ArcGIS online, the folders have maps in them, so I should be able to see these maps in the extension. I watched the YouTube videos about tagging and I did all of that correctly. I'm wondering if anyone would know why I'm not seeing any of my maps in the extension.
Any help would be appreciated! Thanks!
NancyMorales1
HUZZAH!
Yes, that option does exist. If you click and hold you'll see the 3 ways of adding data into the add-on: layers, web maps, and shp.
I'm glad we figured this out.
MadhuraPhaterpekar
To add to Nancy's response you can also start with creating a mapboard from a webmap. In the mapboard window this option is avaialable in the when you click and hold the create and edit mapboards tool. This will create the extent and load the layers all at once when you create a mapboard using a webmap.
