Mapping With Design Tutorial Error
1918
6
08-05-2022 12:24 PM
JustinBurker
Hello I am having trouble with the 4.2 tutorial in Mapping by Design. OSM points does not load. "Too much data to draw. Synced artwork may be unaffected."
Operating System: Windows 10 64-bit
Host Application: ILST 26.4.1
M4CC Version: 3.2.0
License Type: ArcGIS GISProfessionalAdvUT
ERROR: [osm_points - point] Too much data to draw, synced artwork may be unaffected.
Date: 8/5/2022 2:57:25 PM
Extent: xmin=1195470.3320811228 ymin=8376566.84726136 xmax=1198015.4462573729 ymax=8379469.0656791385 spatialReference=102100
MapScale: 4500
MapScale: 4500
SarahBell
Hi @JustinBurker . Could you please retry, and respond with how it goes? The map has been updated, and tested with success on the team's end. I look forward to hearing back from you to see if it works for you as well.
Sarah
JustinBurker
This is when I am adding add content overwrite webmap.
SarahBell
Hi @JustinBurker . Thanks for posting this. I will have the team investigate. While I'm doing that, can you try to move forward with the tutorial anyway. The message you're getting might not impact the final map. I hope that's it!
SarahBell
Hello again, @JustinBurker . This issue has been logged with the dev team, and they are working on it. Stay tuned...
JustinBurker
Thanks.
SarahBell
Sarah
JustinBurker
It loaded thanks!
