Hi @BryanTucker
Could you please verify what account is used to activate the extension. Esri vector basemaps are supported with ArcGIS accounts, not supported with complimentary or ArcGIS Maps for Adobe Plus accounts. Here is a link to the functionality matrix. Please share what account type was used, this will help inform next steps. Thank you for your post.
Hello @MadhuraPhaterpekar
I did sign in using my ArcGIS Online account. I have an ArcGIS pro license.
Bryan
Hi Bryan,
This appears unexpected given your setup is correct. We aren't seeing similar reports like this. Any chance you can report this as a case to Esri technical support. I think a screenshare & additional workflow info might be useful to determine the issue and a cause. Thanks in advance for your help.
Best
Madhura
I figured it out. The option to use base maps was not selected in the organization settings.
This makes sense. I apologize for not catching that earlier and appreciate you posting the solution for all. Thanks @BryanTucker !
