Help with scale and importing .AI to CAD
1115
10-08-2025 07:33 PM
CT_GIS
Hello,
I have just started using ArcGIS Maps for AdobeCC. Part of my workflow requires importing the .AI map to Rhino, a CAD program, in order to create a 1:1 scale drawing in that environment. I have been unable to get my .AI to import to a correct scale so far and I am wondering if there is something I am misunderstanding about the scale of the drawing created by ArcGIS.
I have created an .AI map with the present "streets" level of detail of 1:9027.
My resulting document is 73.01 x 59.01" .
My assumption is that 1 drawing unit = 9027 real units
or 1" on the drawing = 9027 real inches or 752.14'
However, this doesn't ballpark close to dimensions I am measuring on Google Earth:
Feature measured on drawing: .9716 "
Figure measured on Google: 584' = 7008"
This should produce a ratio of 1" = 7213" (7008/0.9716)
I am not sure what I am miscalculating here.
Thanks for any help with this.
Tags (3)
CT_GIS
Also, i am trying to use the feature to add a geodesic scale and get the following error report:
Operating System: Windows 10 64-bit
Host Application: ILST 29.8.2
M4CC Version: 3.9.0
License Type: ArcGIS GISProfessionalAdvUT
ERROR: AddGeodesicScalebar failed. No such element
Date: 10/8/2025 10:45:53 PM
CT_GIS
I have screenshots to upload if permitted. Thanks.
CT_GIS
Update - I created a new illustrator file in CM and generated a new map. This new map succeeded in creating a graphic scale. The "official" scale value was 9050, with a 2.3823 CM line corresponding to 0.1 mi.
I checked this against a measured feature and it is close enough to be correct  (2.5624 CM = 0.108 mi = 570', measured feature = 575').
