Symbology: How can I make a symbol to change color based on overdue date value
7169
14
02-10-2015 12:10 AM
JohanLundgren
I'm exploring symbology with ArcMAp 10.2. I created a feature class and it consists of a field called EndDate of type Date. Next, I would like to create a layer and configure symbology, so that the symbol color changes to red once the date is overdue.
I opened the Layer Properties dialog and the tab Symbology. In the 'Show section, you find Quantities and 'Graduated colors'. But my field (EndDate of data type Date) is not shown in the field called 'Value'.
Any ideas about how I can solve this is very much appriciated.
Are there more possibilities with symbology in ArcMap 10.3?
//Johan
JayantaPoddar
Hi Johan,
Thank you for the information.
You can create a new field with datatype Long in attribute table. In its field calculator, paste the following
Int (Left( [EndDate], 4 ) & Mid( [EndDate], 6, 2 ) &Right( [EndDate], 2  )  )
Then use the above  field to symbolize the data.
Note: The EndDate Format is in YYYY-MM-DD format.
The field name of your EndDate field is "EndDate".
Hope it will solve the issue.
Jay
Think Location
JayantaPoddar
Hi Johan,
What is the format of your EndDate field values (e.g. MM/DD/YYYY)?
Think Location
JohanLundgren
I would like to have the ISO format: YYYY-MM-DD
//Johan
JayantaPoddar
Hi Johan,
Jay
Think Location
JohanLundgren
Many thanks for your help Jay!
I have two fields now EndDate and CalculatedEndDate. The field CalcaulatedEndDate is added with your code, as shown above. When entering and saving a value like 2015-02-10 in EndDate it shows <null> in CalculatedEndDate. Is that the correct result?
Also, do you have any tips on where I add a calculation to show a symbol in red color on overdue, by using my new field CalculatedEndDate?
JayantaPoddar
Hi Johan,
It should show the values without the "-" sign.
Make sure your system Regional Date setting is in same format. And CalculatedEndDate is in Long datatype.
Considering the due date is same for all records, any value more than the CalculatedEndDate is overdue.
Change the symbology accordingly.
Jay
Think Location
JohanLundgren
Thanks Jay!
I can now see the new calculated value for date.
//Johan
JoshWhite
Honored Contributor
Jay,
How would you do it if the original date field is MM/DD/YYYY format?
Nevermind I did some tweaking and came up with
Int (Right( [Date], 4 ) & Left( [Date], 2 ) &Mid( [Date], 4, 2  )  )
So mine went from 01/01/2012 to 20120101
Josh White, AICP
Principal Planner
City of Arkansas City
JayantaPoddar
You are right Josh...
Think Location
MuhammadFayaz
Dear Jay,
What if my date format is DD/MM/YY ?
