Zip Code Boundaries - Fill by group based on join
2028
03-14-2017 06:02 PM
ChristopherMcKinnish
Zip Code Boundaries - Fill by group based on join.
Given:  Zip Code file containing Zip_Code, and an assigned Value Representing a Servicing Facility.
I simply want to join this file to the zip layer, then fill the boundaries with color based upon the assigned value, which would produce a visibly grouping by servicing facility.
This seems like a very basic exercise, yet I cannot find any information about this, or maybe i'm using the wrong verbiage.
Any direction and help is appreciated.
Chris
AbdullahAnter
Honored Contributor
Did you try to use Spatial Join?
Probably should have been more specific.  Yes, I used spatial join.  I have the join, but cannot get the grouping from my excel spreadsheet to display to group by servicing facility.
AbdullahAnter
Honored Contributor
Did you try to Group using Dissolve tool?
Dissolve—Help | ArcGIS Desktop
