Why does the edit tool remove multiple layers at a time?
1415
01-31-2017 07:11 AM
LukeReed
I have created a layer from an existing layer using the select by location tool. I then saved this layer and removed my main layer from the map. I had to trim up the new layer to fit my project. When I add back in the original layer to overlay the new layer and show the changes the original layer has been deleted in the same places as the new separate layer. I have tried this process several times and always get the same result of the original layer being deleted in the same places as the newly created layer.
Any ideas?
RichardFairhurst
Creating a new layer in ArcMap by using copy/paste, saving a layer file or creating a selection layer only creates a new view of the original data, not a new copy of the original data.  This is useful for changing symbology, labeling and other presentation properties of the copied layer within a map of a single data source.  It is not useful for duplicating a data source so that the original data source is untouched by editing.
To create a copy of the original data source you need to export the layer (right-click the layer->Data->Export), copy/paste the feature class in ArcCatalog, or use a geoprocessing tool that copies a feature class like the Feature Class to Feature Class tool.
LukeReed
Thank you very much Richard. I was getting frustrated. This makes sense now.
