Why Does ArcGIS Pro Disable ability to change axis to log?
4195
9
02-26-2019 08:01 PM
RaulGarcia
I am currently doing the lesson "Help End Homelessness" on learn.arcgis.com. I am on the part where I am supposed to make a chart and adjust the x and y - axis to log, but on my version of arcGIS Pro, which is the most current one, only allows me to adjust the y - axis to log and not the x - axis. Could anyone help me understand why ArcGIS Pro doesn't let me adjust the x - axis?
RaulGarcia
 It's a scatter plot by the way. Thank you for the links, but it doesn't explain why a certain axis is being disabled an how to enable log onto the axis.
DanPatterson_Retired
worked for me, after specifying 2 numeric fields, the option to specify a log axis was there... for both line and scatter
RaulGarcia
Well I don't know why mine is disabled as shown if I followed the instructions on This Lesson.
Log axis being disabled for x-axis
Well if you got the chart on step 16 exactly and it won't go to the next step
scroll to the bottom of that page and send an email to the Feedback on this Link... they will look into it
RaulGarcia
Well I don't know what else to do so I'll do that. Thanks for trying to help out!
SethHiatt
Raul, I had the same problem. The checkbox was activated once I unchecked "Show linear trend" under the Data tab.
Seth
ConorChurch
Raul,
I know it's been 2 years but just wanted to add my 2 cents if others in the future find this post from Google, like I did.
I had the same problem. The only thing that eventually worked for me was to check "show linear trend," save the project, and quit. Then once I reopened the project and deselected "show linear trend" the option to select log axes for both axes was enabled.
Hope this helps the next person!
TimKeeping
Log curves cannot display zero (0) and my problem was a zero (0) in my column keeping the log tick box grey. Luckily I could change to a very small magnetic susceptibility instead (0.00001).
