labels over annotations
4310
10-31-2014 04:51 PM
JanKlasa
I have a problem - some labels goes over annotations in my map. So my question is: How to prevent Maplex labels from placing over geodatabase annotations (annotations must be intact)?
Thank you very much for help!
AnnaSchwabedal
Hi Jan,
Labels are the last item which is drawn on a map in ArcMap. You can prevent label overplacing Annotations by using Feature Weight , see here  ArcGIS Help (10.2, 10.2.1, and 10.2.2)
Annotations are features, therefor you can use that option.
Another way is described here: Esri Mapping Centre - Ask a Cartographer
hope that helps.
Kind regards,
Anna
Technical Support Esri Germany
AnnaSchwabedal
Hi Jan,
hope that helps.
Kind regards,
Anna
JanKlasa
Hi Anna,
problem labels over annotations is solved. Thank you very much for your help!
I apologize for my late reply but I was on terrain mapping.
Jan
