Import shapefile online
2254
05-26-2016 08:28 AM
JoelMeier1
I'm trying to add a .shp to my www.arcgis.com​ webmap and the shapefiles keep appearing in the middle of the pacific no matter which projection I try and use. Can anyone give me suggestions on how to fix this?
Also not sure if I'm putting this in the right place. please let me know if I need to move it
DanPatterson_Retired
in arcmap, rightclick on the layer, bring up properties, then look for the projection and extent in the general/source tab.  It is likely that the file had a defined projection, so changing it to something else, will foul it up.  Check the extents, do they like they are in decimal degrees (-180 to 180 EW and -90 to 90 NS range) or are the numbers large (could be in one of hundreds of projections.)
Webmaps tend to use a web mercator projection (although not guaranteed), so you should check your environments and files before you change them
AdrianWelsh
MVP Honored Contributor
Hi Joel,
When you view the shapefile in ArcGIS Desktop, is it showing up where it is supposed to? Can you upload the shapefile here so others can test it?
JoelMeier1
Using Mercator worked, it was in UTM 17.
Thank you
