How do I create and display the row and column of a hexagon grid
8447
6
07-02-2015 03:47 PM
StephenRider
I'm trying to figure out how to make display coordinates of each hexagon in a hex array. The numbers are a combination of the row and column of the hexagon. The following is an example of what I'm trying to do:
Thanks!
XanderBakker
Esri Esteemed Contributor
Oh dear, mmm, I guess I did something wrong here... I used some code to create hexagons and analyzed the rows and columns to create the labels, but my hexagons are oriented differently... Oops. This is my result (I added the R and C to show what value represents the row and which one the column):
The code I used is:
import math
import arcpy
import os
# http://stackoverflow.com/questions/26691097/faster-way-to-calculate-hexagon-grid-coordinates
def calc_polygons_new(startx, starty, endx, endy, radius):
    sl = (2 * radius) * math.tan(math.pi / 6)
    # calculate coordinates of the hexagon points
    p = sl * 0.5
    b = sl * math.cos(math.radians(30))
    w = b * 2
    h = 2 * sl
    # offsets for moving along and up rows
    xoffset = b
    yoffset = 3 * p
    row = 1
    shifted_xs = []
    straight_xs = []
    shifted_ys = []
    straight_ys = []
    while startx < endx:
        xs = [startx, startx, startx + b, startx + w, startx + w, startx + b, startx]
        straight_xs.append(xs)
        shifted_xs.append([xoffset + x for x in xs])
        startx += w
    while starty < endy:
        ys = [starty + p, starty + (3 * p), starty + h, starty + (3 * p), starty + p, starty, starty + p]
        (straight_ys if row % 2 else shifted_ys).append(ys)
        starty += yoffset
        row += 1
    polygons = [zip(xs, ys) for xs in shifted_xs for ys in shifted_ys] + [zip(xs, ys) for xs in straight_xs for ys in straight_ys]
    return polygons
# create hexagons
result = calc_polygons_new(0, 0, 10, 10, 1)
cnt = 0
lst_x = []
lst_y = []
dct_hex = {}
for hexa in result:
    lst = []
    cnt += 1
    for tpl in hexa:
        pnt = arcpy.Point(tpl[0], tpl[1])
        lst.append(pnt)
    polygon = arcpy.Polygon(arcpy.Array(lst))
    x = polygon.labelPoint.X
    y = polygon.labelPoint.Y
    lst_x.append(x)
    lst_y.append(y)
    dct_hex[cnt] = [polygon, x, y]
# sort x and y label points lists
lst_x = sorted(list(set(lst_x)))
lst_y = sorted(list(set(lst_y)))
# create column number
col = 0
dct_x = {}
for x in lst_x:
    col += 1
    dct_x = col
# create row number
row = 0
dct_y = {}
for y in reversed(lst_y):
    row += 1
    dct_y = row
# define label
for cnt, lst in dct_hex.items():
    x = lst[1]
    y = lst[2]
    row = dct_y
    col = dct_x
    lbl = "C{0} R{1}".format("%02d" % (col,), "%02d" % (row,))
    lst.append(lbl)
    dct_hex[cnt] = lst
# create empty fc
arcpy.env.overwriteOutput = True
out_fc = r"C:\Forum\Hexagon\hexa03.shp"
path, name = os.path.split(out_fc)
arcpy.CreateFeatureclass_management(path, name, "POLYGON")
# insert hexagons
fld_lbl = "Label"
arcpy.AddField_management(out_fc, fld_lbl, "TEXT", None, None, 10)
flds = ("SHAPE@", fld_lbl)
with arcpy.da.InsertCursor(out_fc, flds) as curs:
        row = (lst[0], lst[3],)
        curs.insertRow(row)
I'm gonna dive into this again and generate the hexagons like you show in the image.
DanPatterson_Retired
Xander there are two representations of hexagons...pointy-headed and flat-headed (and they aren't my terms).  I document both on my blog:
Numpy Snippets # 3 ... Phish_Nyet ... creating sampling grids using numpy and arcpy and
NumPy Snippets # 4... N-gons... Regular polygonal shape generation .
One of them has some code for numbering but it is different than the method you used, to give some options.
So pick your type and number accordingly.
XanderBakker
Hi Dan Patterson , thanks for reminding me of what numpy is capable. Great links!
XanderBakker
Okay, a second test looks like this:
... and applying the label format from your example:
The code I used for this was:
import math
import arcpy
import os
def generate_hexagons(startx, starty, endx, endy, radius):
    hex_h = math.sin(math.radians(60)) * radius * 2
    hex_w = radius + math.cos(math.radians(60)) * radius
    cols = int(math.ceil((endx - startx) / hex_w))
    rows = int(math.ceil((endy - starty) / hex_h))
    dct = {}
    cnt = 0
    for col in range(cols):
        for row in range(rows):
            cnt += 1
            x = startx + (col * hex_w)
            y = endy - (row * hex_h)
            m = col % 2 == 1
            polygon = create_hexagon(x, y, radius, m)
            dct[cnt] = [polygon, col+1, row+1]
    return dct
def create_hexagon(x, y, radius, shift):
    lst = []
    shift_y = -1 * (math.sin(math.radians(60)) * radius) if shift else 0
    for a in range(7):
        angle = a * 60
        lst.append(arcpy.Point(x + math.cos(math.radians(angle)) * radius, y + math.sin(math.radians(angle)) * radius + shift_y))
    return arcpy.Polygon(arcpy.Array(lst))
# create empty fc
out_fc = r"C:\Forum\Hexagon\hexa2v05.shp"
# generate the hexagons from 0,0 to 10,10 with a radius of 1
dct = generate_hexagons(0, 0, 10, 10, 1)
# write the hexagons to a fc
fld_lbl = "Label"
    for cnt, lst in dct.items():
        polygon = lst[0]
        col = lst[1]
        row = lst[2]
        # lbl = "C{0} R{1}".format("%02d" % (col,), "%02d" % (row,))
        lbl = "{0}{1}".format("%02d" % (col,), "%02d" % (row,))
        row = (polygon, lbl,)
        curs.insertRow(row)
If you have any questions let me know.
Kind regards, Xander
XanderBakker
Nice!!! Hexagons are where its at
