grid labels
4516
10-28-2014 09:51 AM
Jonathan_L_Robinson
when adding a grid to your map, how can I add a halo to those grid labels? When going through the wizard, it says I'll have a halo, but it never adds it.
FugroSurvey_Ltd_
Hi Jon,
have you found anything on this issue yet?
I am having the same problem and tried everything I could think of with no results.
XanderBakker
Esri Esteemed Contributor
I have noticed that while creating the graticule or measured grid you can define the Halo effect for the labels, but they don't show. When entering the properties of the grid you can no longer specify a Halo effect of the labels.
I don't think you are going to like this, but... if you extent is static, you could convert it to graphics, ungroup the labels and apply the Halo effect to them (see example to the left).
