Annotation Callout Leading Parameter - Help
4664
04-01-2014 11:10 PM
by Anonymous User
Not applicable
Original User: Celil
Hello Team,
Leading parameter works perfectly when there is two rows to give leading (LIN parameter) which consist of same font sized texts but I need to give same leading to three rows which have different sized texts at the rows and have the same leading value for textelement. It seems leading value can be affected from different font size values. Is there anyway to make leading value same between three or more rows. You can check it for toptextelement by cut&paste script at the attachment to any annotation and also the pictures show the problem.
Thanks
by Anonymous User
Not applicable
Original User: AeronauticalSolutionTeam
Hi Celil
Since the font size on each line is different you would need to set different leading values for each line. I'm attaching an updated version of your text let us know if this is what you are looking for.
Aviation Team
by Anonymous User
Not applicable
Hi Celil
Aviation Team
Yusuf_CelilKonak
Hello team,
That's the exactly what I was looking for. Thanks for the help.
Greetings from 4th ESRI European Aviation Summit, Manchester.
