Unable to create API key in Developer Dashboard
3121
09-15-2023 06:47 PM
Labels (2)
kclarkGIS
Hello,
I am trying to follow this tutorial and I need to create an API key in the Developers Dashboard. I am signed in with an organizational account but I do not see the tab for API. Is there some other setting that needs to be enabled for me to complete this step?
Thanks in advance!
kclarkGIS
Thanks for the response, @John-Foster . I worked with Esri support and found the issue, I elaborated on it in this post here:
https://community.esri.com/t5/arcgis-runtime-sdk-for-android-questions/i-cant-find-api-key-in-dashbo...
John-Foster
@kclarkGISAlthough you are logged in with an Organization account, the API Keys tab is not appearing (it should appear next to the OAuth 2.0 tab) that would indicate either you are logged in with an account with limited privileges such as a trial account, education account, personal use. Can you contact your Organization Administrator and have your user type escalated to a Creator account? If not you can sign up with a separate account go to https://developers.arcgis.com/sign-up/ and sign up for a free developer account.
--jf
kclarkGIS
