packaging.arcgis.com high-level questions
4099
10
05-29-2018 10:26 AM
CamBarnard
Raúl Jiménez Ortega
I've read through the documentation several times at:
Create Map Area—ArcGIS REST API: Packaging Service | ArcGIS for Developers
Setup Map Area—ArcGIS REST API: Packaging Service | ArcGIS for Developers
Refresh Map Area Package—ArcGIS REST API: Packaging Service | ArcGIS for Developers
Q1: These APIs currently work against ArcGIS Online, not yet against Portal for ArcGIS Enterprise. Correct?
Q2: I'm struggling to understand the differences between Setup Map Area and Create Map Area. Can you explain?
Q3: Is there an intended flow where all three of these APIs are to be used together? e.g. Setup > Create > Refresh?
I'm about to embark on some proof of concept work, but a high-level understanding before starting would be GREAT
Cam Barnard
CamBarnard
Hi David - yes that was the most common 'incorrect' response when asking for status, I think there was one other that I'd occasionally see but I'll have to capture it next time I run through the sequence (which I plan to do after making my initial web map more complicated).
I sometimes see this as well.
