I struggle sometimes with living atlas giving me data for areas that are no where near the area I am working in within ArcgisPro? I am looking for an easy way to filter results or any option based on the current area of interest in your project not the entire world. It is a great feature and I would like to explore it more but have data show up for somewhere in Africa when I am looking for Texas specific data does not help.
Andrew - yes there is. If you use item fields, click on the Living Atlas icon in the Catalog Pane and type a item field such as tags:Texas - hit Enter. Then only the Living Atlas items that have a tag of Texas show up in the results.
Yes, if you're working in ArcGIS Online, you can apply a filter. This blog post walks you through a few ways to do that: Apply Filters to Make Living Atlas Layers Work For You
-Diana
You both have good points but in AGP when you do the Texas search you only receive items with Texas in the meta data or title. That search leaves out a ton of different image and data sources such as NAIP imagery, roads, population, water data to name a few. It wold be great if Living Atlas had an option to only show features that cover the extent of your mapping project.
Ahh, I understand now. I personally haven't found a way to do this in Pro yet, but in ArcGIS Online, you can do this while searching for layers from within the Map Viewer by toggling on the "only show content within the map area" option:
That's exactly what I am looking for in AGP!
Andrew - it seems you're not alone in wanting a better way to filter Living Atlas - there's a GeoNet idea here.
