Let user decide which data field to be used as display name
1249
02-13-2025 06:05 PM
Status: Implemented
xingchenc
Currently, when we use the load table tool to import data to knowledge graph, we can't decide which data field to be used as the disaply name in the investigation, and once the knowledge graph is created, we can't change display name either.
Please make this more flexible!
2 Comments
AdamMartin
Thanks @xingchenc  for the comment. We heard this from a lot of folks, and luckily have addressed this in Pro 3.4 which is already released. I hope you are able to access this latest version soon.
In the Investigation view, you can right click on then Entity or Relationships Type, Choose Properties, and then select a different Property to be your Display Name. You can also use an Arcade Expression to customize further.
See the example quick example below and let us know if you have more questions or enhancement ideas.
xingchenc
@AdamMartin  thanks for making it happen, that's great news!
