Zoom out after Geocoder finds match
3907
07-08-2015 11:38 AM
TimWitt2
Hey everybody,
In my javascript application I use the ESRI Geocoder and once a match has been selected it zooms to the match.
What I try to do is after my map zooms to the match I want to zoom out to a specific extent, which should be possible by using map.setExtent().
This only works if I am in developer mode and I put a break point at map.setExtent() , which leaves me to believe that the zooming initiated by the geocoder takes some time and happens after I do map.setExtent()
Since Jive hates me posting code, I have put the relevant code in this fiddle: Edit fiddle - JSFiddle
Thanks for any help!
Tim
RobertScheitlin__GISP
Tim,
   Have you looked at setting the Geocoders autoNavigate property to false seems how you are not wanting the extent that the Geocoder takes you to?
Geocoder | API Reference | ArcGIS API for JavaScript | autoNavigate
Tim,
TimWitt2
Thanks Robert, that's exactly what I needed.
