Zoom In/Out tool becomes disabled
2356
5
01-30-2014 06:55 AM
ShaningYu
Honored Contributor
In my thread at http://forums.arcgis.com/threads/101760-Map-does-not-display?p=362307&posted=1#post362307, I reported a problem when I switched API from 2.x to 3.8: The TOC does function well.  Per Ken's advisory, the TOC problem got solved, but the Zoom In/Out tool at the top-left of the panel becomes disabled.  Hopefully someone can help me for this debugging.
ShaningYu
Honored Contributor
Ken:  Thanks.  First time tried JSBin.  My code is at http://jsbin.com/ilElaWa/2/edit?html,output.  Could you view it on your side?  Thanks.
KenBuja
MVP Esteemed Contributor
Can you replicate it in JSBin? It's very difficult to debug something without any code.
ShaningYu
Honored Contributor
KenBuja
It looks likes your services aren't publicly available. I only see this.
[ATTACH=CONFIG]30979[/ATTACH]
ShaningYu
Honored Contributor
Ken:  Thanks for your time to review.  I have solved this problem already just by multiple tries.  Your info about JSBin is very useful.  You feedback is to be credited as 'Solved'.
JeffPace
i think you marked the wrong post as answered
