xhrFailed  when i  add"dojo.require("esri.diji.Popup");"
2523
10-25-2012 01:17 AM
yanli
Today  i  add  the  code   "dojo.require("esri.diji.Popup");" it get the error "xhrFailed" IN IE 8
I  put  the api  in the  local computer,
what't  wrong   ?????????1!!!!!!!!!!
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
    <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>QueryTask with query geometry from another task</title>
  <link rel="stylesheet" type="text/css" href="http://localhost/arcgis_js_api/library/3.1/jsapi/js/dojo/dijit/themes/claro/claro.css">
  <link rel="stylesheet" type="text/css" href="http://localhost/arcgis_js_api/library/3.1/jsapi/js/esri/dijit/css/Popup.css">
   <script type="text/javascript">var dojoConfig = {parseOnLoad: true};</script>
    <script type="text/javascript" src="http://localhost/arcgis_js_api/library/3.1/jsapi/"></script>
       dojo.require("dijit.layout.BorderContainer");
      dojo.require("dijit.layout.ContentPane");
      dojo.require("esri.map");
      dojo.require("esri.tasks.query");
      dojo.require("esri.tasks.geometry");
      var map;
      /*Initialize map, buffer, & query params*/
      function init() {
    // var popup = new esri.dijit.Popup(null, dojo.create("div"));
   //  var popup = new esri.dijit.Popup({
      //    fillSymbol: new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 2), new dojo.Color([255,255,0,0.25]))
      //  }, dojo.create("div"));
        var startExtent = new esri.geometry.Extent({"xmin":542658.416722138,"ymin":72762.5001166421,"xmax":690341.583278327,"ymax":165987.499005236});
        map = new esri.Map("mapDiv", { });
        //listen for when map is loaded and then add query functionality
        dojo.connect(map, "onLoad", initFunctionality);
        var imageParameters = new esri.layers.ImageParameters();
        imageParameters.format = "jpeg";  //set the image type to PNG24, note default is PNG8.
 // dynamicMapServiceLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://localhost/ArcGIS/rest/services/ditu/MapServer", {"opacity":1, "imageParameters":imageParameters});
      var   dynamicMapServiceLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://localhost/arcgis/rest/services/TuJB5/MapServer", {"opacity":1, "imageParameters":imageParameters});
        map.addLayer(dynamicMapServiceLayer);
      function initFunctionality(map) {
        var queryTask = new esri.tasks.QueryTask("http://localhost/arcgis/rest/services/TuJB5/MapServer/1");
        //identify proxy page to use if the toJson payload to the geometry service is greater than 2000 characters.
        //If this null or not available the buffer operation will not work.  Otherwise it will do a http post to the proxy.
     //   esri.config.defaults.io.proxyUrl = "/arcgisserver/apis/javascript/proxy/proxy.ashx";
     //   esri.config.defaults.io.alwaysUseProxy = false;
        // Query
        var query = new esri.tasks.Query();
        query.returnGeometry = true;
        query.outFields =  ["GEOOBJNUM"];
        query.outSpatialReference =  map.spatialReference;
        var infoTempContent = ""
            + "<br/><A href='#' onclick='map.graphics.clear();getfeature();'>Remove Selected Features</A>";
        //Create InfoTemplate for styling the result infowindow.
        var infoTemplate = new esri.InfoTemplate("Block: ${GEOOBJNUM}", infoTempContent);
        map.infoWindow.resize(275,190);
        var currentClick = null;
        // +++++Listen for map onClick event+++++
        dojo.connect(map, "onClick", function(evt) {
          map.infoWindow.hide();
          currentClick = query.geometry = evt.mapPoint;
          query.spatialRelationship = esri.tasks.Query.SPATIAL_REL_INTERSECTS;
          queryTask.execute(query);
          dojo.byId('messages').innerHTML = "<b>Executing Point Intersection Query...</b>";
        var firstGraphic = null;
        // +++++Listen for QueryTask onComplete event+++++
        dojo.connect(queryTask, "onComplete", function(graphics) {
          firstGraphic = graphics.features[0];
          var symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new dojo.Color([100,100,100]), 3), new dojo.Color([255,0,0,0.20]));
          firstGraphic.setSymbol(symbol);
        //  firstGraphic.setInfoTemplate(infoTemplate);
          map.graphics.add(firstGraphic);
 //   map.infoWindow.setFeatures([ graphics ]);
     //   map.infoWindow.show(currentClick );
   function  getfeature()
      if(map.infoWindow.isShowing){
   alert("have the feature")
          //  var loc = map.infoWindow.getSelectedFeature().geometry;
  // var lg=loc.rings.length;
   //alert(lg);
          //  if(!map.extent.contains(loc)){
          //    map.infoWindow.hide();
    else
    alert("No the  feature");
      dojo.addOnLoad(init);
    </script>
  </head>
  <body class="claro">
    Click on map to select census block group that intersects the map click and all block groups that touch selected group.
    <div id="mapDiv" style="width: 850px; height:500px; position:relative;"></div>
    <span id="messages"></span>
  </body>
</html>
JeffJacobson
Add a "t" after "esri.diji".
