Why won't my dojo grid display in my bootstrap dialog box?
13937
19
07-31-2015 11:57 AM
ChrisSergent
I am using this sample here: http://www.w3schools.com/bootstrap/bootstrap_modal.asp  to attempt to create a bootstrap dialog box. The only problem is I can't get the dojo grid to display inside of my modal dialog box. What am I doing wrong?
Here is my code with references as to where I am trying to display the modal and the grid.
<!DOCTYPE html>
<html>
<head>
    <meta charset="utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=edge">
    <meta name="viewport" content="width=device-width, initial-scale=1.0">
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.14/dojox/grid/resources/Grid.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/dojox/grid/resources/claroGrid.css">
    <link rel="stylesheet" href="http://maxcdn.bootstrapcdn.com/bootstrap/3.3.5/css/bootstrap.min.css">
    <script src="https://ajax.googleapis.com/ajax/libs/jquery/1.11.3/jquery.min.js"></script>
    <script src="http://maxcdn.bootstrapcdn.com/bootstrap/3.3.5/js/bootstrap.min.js"></script>
    <title></title>
    <style>
        #myModal {
            height:80%;
    </style>
    <!-- HTML5 shim and Respond.js IE8 support of HTML5 elements and media queries -->
    <!--[if lt IE 9]>
       <script src="//cdnjs.cloudflare.com/ajax/libs/html5shiv/3.7/html5shiv.min.js"></script>
       <script src="//cdnjs.cloudflare.com/ajax/libs/respond.js/1.4.2/respond.min.js"></script>
    <![endif]-->
    <script type="text/javascript">
    var dojoConfig = {
        parseOnLoad: true,
        isDebug: true,
        locale: 'en-us',
        extraLocale: ['ja-jp']
    </script>
    <!-- This will not work if you set the html lang https://community.esri.com/thread/81475 -->
  <script src="http://js.arcgis.com/3.14/"></script>
   <style>
       .modal-body, #grid
           height:500px;
   </style>
</head>
<body class="claro">
    <label id="lblOwnerAddress" for="ownerAddress">Owner's Address</label>
    <input type="text" id="ownerAddress" name="ownerAddress" value="111 S Main" />
    <div class="container">
        <!-- Modal -->
        <div class="modal fade" id="myModal" role="dialog">
            <div class="modal-dialog">
                <!-- Modal content-->
                <div class="modal-content">
                    <div class="modal-header">
                        <button type="button" class="close" data-dismiss="modal">&times;</button>
                        <h4 class="modal-title">Modal Header</h4>
                    </div>
                    <div class="modal-body">
                        <table data-dojo-type="dojox/grid/DataGrid" data-dojo-id="grid" id="grid" data-dojo-props="rowsPerPage:'5', rowSelector:'20px'">
                            <thead>
                                <tr>
                                    <th field="address" width="200px">Address</th>
                                    <!--<th field="score">Scrore</th>-->
                                </tr>
                            </thead>
                        </table>
                    </div>
                    <div class="modal-footer">
                        <button type="button" class="btn btn-default" data-dismiss="modal">Close</button>
                    </div>
                </div>
            </div>
        </div>
    </div>
    <script>
        var items;
    require([
            "dojo/on",
            "dojo/_base/array",
            "esri/tasks/locator",
            "dojox/grid/DataGrid",
            "dojo/data/ItemFileReadStore",
            "dijit/registry", "dojo/parser",
            "dijit/layout/ContentPane",
            "dojo/domReady!"
     function (on, arrayUtils, Locator, DataGrid, ItemFileReadStore, registry, parser) {
         parser.parse();
         document.getElementById("grid").style.display = "none";
         on(document.getElementById('ownerAddress'), 'focusout', checkAddress);
         function checkAddress() {
             var locator = new Locator("http://maps.decaturil.gov/arcgis/rest/services/Public/WebAddressLocator/GeocodeServer");
             //console.log(document.getElementById('ownerAddress').value);
             var node = document.getElementById('ownerAddress');
             // according to your service it takes Single Line
             var params = {
                 "Single Line Input": node.value
             locator.addressToLocations(params).then(function (addressCandidates) {
                 //console.log('success', addressCandidates);
                 //console.log(addressCandidates.length);
                 if (addressCandidates.length > 1) {
                     for (a = 0; a < addressCandidates.length; a++) {
                         // This is the address that should go into a grid cell
                         console.log(addressCandidates.address);
                     console.log(addressCandidates);
                     items = arrayUtils.map(addressCandidates, function (result) {
                         console.log(result);
                         return result;
                     console.log(items);
                 var data = {
                     items: items
                 console.log("Log" + data);
                 store = new ItemFileReadStore({
                     data: data
                 // display grid
                 document.getElementById("grid").style.display = "block";
                 // Show modal
                 $("#myModal").modal("show");
                 var grid = registry.byId("grid");
                 grid.setStore(store);
                 //registry.byId("grid").display=block;
                 grid.on("rowclick", onRowClickHandler);
                 var adresses = addressCandidates.map(function  {
                     return x.address;
                 //console.log(adresses);
             }).otherwise(function (err) {
                 console.log('somethings wrong', err);
         function onRowClickHandler(evt) {
             console.log(evt);
             var clickedAddress = evt.grid.getItem(evt.rowIndex).address;
             console.log(clickedAddress);
             alert(clickedAddress);
             //  console.log(evt.explicitOriginalTarget.data);
    </script>
</body>
</html>
Tags (3)
TracySchloss
Honored Contributor
I had several sets, but it seems like you can replicate.  I set one for items, store and for the line grid.setStore(store).  Doing that the modal is populating.
ChrisSergent
I was able to see the datagrid through debugging too.
I tried to pause before and after the grid.setStore like so:
// Show modal
                    window.setTimeout(function () { }, 5000);
but that didn't do anything.
TracySchloss
Honored Contributor
I tried changing it around to have a listener as
on (locator, 'address-to-locations-complete', populateModal);
thinking that it wasn't having enough time to get all the candidates before it tried to populate the store, but that didn't help.
Is there a reason you aren't using the Search widget and just defining your own locator as the source?  It should handle the list of candidates for you.
ChrisSergent
I was asked to validate text boxes after users entered in addresses, otherwise this would be a lot simpler.
TracySchloss
Honored Contributor
Since I'm used to dGrid and Memory for my store, I changed this up. It works for me now with no breakpoints.
<!DOCTYPE html>
<html>
<head>
<meta name="generator" content="HTML Tidy, see www.w3.org">
<link type="text/css" rel="stylesheet" href=
<script type="text/javascript" src=
</script>
</script>
<title></title>
<style type="text/css">
    #myModal {
        height: 80%;
</style>
<!--[if lt IE 9]>
        <![endif]-->
    var dojoConfig = {
        parseOnLoad: true,
        isDebug: true,
        locale: 'en-us',
</script>
<script type="text/javascript" src="http://js.arcgis.com/3.14/">
</script>
    .modal-body, #grid {
        height: 500px;
</style>
</head>
Address</label> <input type="text" id="ownerAddress" name=
"ownerAddress" value="111 S Main">
    <!-- Modal -->
                    Header</h4>
                </div>
                  <div id="gridDiv"></div>
                </div>
                </div>
            </div>
        </div>
    </div>
</div>
var items;
require([
                "dojo/on",
                "dojo/_base/array",
                "dgrid/OnDemandGrid",
                'dojo/store/Memory',
                "dojo/domReady!"
        function (on, arrayUtils, Locator, DataGrid, dGrid, Memory, ItemFileReadStore, registry, parser) {
            parser.parse();
          var grid = new dGrid({
        selectionMode: 'single',
        columns: { addess:'Candidate'},
        loadingMessage: 'Loading data...'
    }, "gridDiv");
    grid.startup();
                var params = {
                locator.addressToLocations(params);
          function populateModal(addressCandidates){
            if (grid) {
                grid.refresh();
            if (addressCandidates.addresses.length > 1) {
                  items = arrayUtils.map(addressCandidates.addresses, function (result,idx) {
                            return {
                              'id':idx,
                              'address':result.address
                  var currentMemory = new Memory({
                        data: items,
                        idProperty: 'id'
                  grid.set('store', currentMemory);
                console.log(evt);
</script>
</body>
</html>
ChrisSergent
Did it display addresses for you? There should be two addresses when you tab out of the textbox.
ChrisSmith7
Honored Contributor
Chris,
in follow-up to our discussion in How do I write address candidates to a grid?, I think you have the right idea trying to construct this declaratively. I have had problems in the past when trying to render stuff in the modal dialog programmatically. I hacked something together, though, that accomplishes this:
GRID modal test - JSFiddle
Sorry, it's messy... I haven't had a chance to clean it up. Essentially, I had to trigger an event to render the grid after the modal dialog was visible, otherwise, it didn't know how to render completely on startup. While the modal dialog appears responsive, the grid does not... but it should get you in the right direction.
ChrisSergent
Chris,
Awesome! There was some duplication in the code, but it worked out great!
Had no idea why it would show up. Thanks for adding the documentation as well.
Here is my complete code for anyone that needs it:
<!DOCTYPE html>
<html>
<head>
    <title></title>
    <style>
        #gridDiv {
            height: 100%;
            width: 100%;
        #myModal {
            height: 100%;
            width: 100%;
        .modal-body {
            height: 300px;
    </style>
    <!--[if lt IE 9]>
    <![endif]-->
</head>
        <div id="mainDiv" class="container">
            <!-- Modal -->
                        </div>
                        </div>
                        </div>
                    </div>
                </div>
            </div>
        </div>
        <script>
            var items;
            require([
                    "dojo/on",
                    "dojo/_base/array",
                    "dojo/data/ItemFileWriteStore",
                    "dijit/registry",
                    "dojo/dom",
                    "dojo/_base/lang",
                    "dojo/domReady!"
            function (on, arrayUtils, Locator, DataGrid, ItemFileWriteStore, registry, parser, registry, dom, lang) {
                parser.parse();
                var store, grid, data, layout;
                //document.getElementById("grid").style.display = "none";
                    var params = {
                        data = {
                            identifier: "id",
                            items: []
                        layout = [[
                        //  {'name': 'FID', 'field': 'id', 'width': '50px'},//
                          { 'name': 'Address', 'field': 'address', 'width': '200px' }
                                data.items.push(lang.mixin({ id: a + 1 }, { address: addressCandidates.address }));
                                return result;
                            console.log(items);
                        if (window.grid) {
                            dojo.destroy('grid');
                            dijit.byId('grid').destroy(true);
                            registry.remove(dom.byId('gridDiv'));
                        store = new ItemFileWriteStore({ data: data });
                        grid = new DataGrid({
                            store: store,
                            structure: layout,
                            autoWidth: true,
                            autoHeight: false,
                            rowSelector: '20px'
                        // display grid
                        //document.getElementById("grid").style.display = "block";
                        // Show modal
                        $('#myModal').show(function () {
                            $(this).trigger('isVisible');
                        //hookup the event
                        $('#myModal').bind('isVisible', isVisible);
                        var adresses = addressCandidates.map(function () {
                            return x.address;
                //declare event to run when div is visible
                function isVisible() {
                    /*append the new grid to the div*/
                    grid.placeAt("gridDiv");
                    /*Call startup() to render the grid*/
                    grid.startup();
                    console.log(evt);
        </script>
</body>
</html>
ChrisSmith7
Honored Contributor
Cool - glad to help! We have a big initiative to retrofit our app to make it responsive using Bootstrap... it's a pretty slick framework. One thing I may need to revisit is how the dialog is created/destroyed... I'm probably being a little heavy-handed in this approach, but I didn't have luck trying to update the control if it already existed in the DOM.
ChrisSergent
I have seen the issue of needing to destroy items before due to conflicts. If you are interested I would be willing to help learn/create a Bootstrap template on Github to make a responsive app. Still learning responsive, but I am very much into learning new things and very active into helping out when I can and would welcome the challenge.
