Why won't my code run a second time on lost focus of an element?
3847
08-18-2015 12:40 PM
ChrisSergent
I run a block of code that runs off of lost focus. It runs fine the first time, but then I try to set focus to a textbox(which appears not to work) so I click in the textbox and tab out. The lost focus event does not work that time? Why is that?
Here is the related code:
 on(document.getElementById('ownerAddress'), 'focusout', checkAddress);
                 on(document.getElementById('ownerAddress'), 'focusin', getElementId);
                 function getElementId() {
                     node = document.activeElement.id;
                 function checkAddress() {
                     console.log(node);
                     var locator = new Locator("http://maps.decaturil.gov/arcgis/rest/services/Public/WebAddressLocator/GeocodeServer");
                     //console.log(document.getElementById('ownerAddress').value);
                     //node = document.getElementById('ownerAddress');
                     node = document.getElementById(node);
                     // according to your service it takes Single Line
                     var params = {
                         "Single Line Input": node.value
                     locator.addressToLocations(params).then(function (addressCandidates) {
                         //console.log('success', addressCandidates);
                         //console.log(addressCandidates.length);
                         data = {
                             identifier: "id",
                             items: []
                         layout = [[
                        //   {'name': 'FID', 'field': 'id', 'width': '50px'},//
                           { 'name': 'Address', 'field': 'address', 'width': '200px' }
                         if (addressCandidates.length > 1) {
                             for (a = 0; a < addressCandidates.length; a++) {
                                 // This is the address that should go into a grid cell
                                 data.items.push(lang.mixin({ id: a + 1 }, { address: addressCandidates.address }));
                                 console.log(addressCandidates.address);
                             console.log(addressCandidates);
                             items = arrayUtils.map(addressCandidates, function (result) {
                                 console.log(result);
                                 return result;
                             console.log(items);
                         console.log("Log" + data);
                         if (window.grid) {
                             Maingds
                             dojo.destroy('grid');
                             dijit.byId('grid').destroy(true);
                             registry.remove(dom.byId('gridDiv'));
                         store = new ItemFileWriteStore({ data: data });
                         grid = new DataGrid({
                             store: store,
                             structure: layout,
                             autoWidth: true,
                             autoHeight: false,
                             rowSelector: '20px'
                         // display grid
                         //document.getElementById("grid").style.display = "block";
                         //alert("hello " + addressCandidates.length);
                         // Show modal
                         if (addressCandidates.length >= 1) {
                             $("#myModal").modal("show");
                             $('#myModal').show(function () {
                                 $(this).trigger('isVisible');
                             //registry.byId("grid").display=block;
                             grid.on("rowclick", onRowClickHandler);
                             //hookup the event
                             $('#myModal').bind('isVisible', isVisible);
                             var adresses = addressCandidates.map(function () {
                                 return x.address;
                             //console.log(adresses);
                         else
                             alert("This address does not appear to be a city address. Please try again.");
                             document.getElementById(node).focus();
                     }).otherwise(function (err) {
                         console.log('somethings wrong', err);
                 //declare event to run when div is visible
                 function isVisible() {
                     /*append the new grid to the div*/
                     grid.placeAt("gridDiv");
                     /*Call startup() to render the grid*/
                     grid.startup();
                 function onRowClickHandler(evt) {
                     console.log(evt);
                     var clickedAddress = evt.grid.getItem(evt.rowIndex).address;
                     console.log(clickedAddress);
                     alert(clickedAddress);
                     //  console.log(evt.explicitOriginalTarget.data);
ChrisSergent
What I needed to do was to evaluate the number of addresses at the beginning of my statement. Here is the resolution:
<!DOCTYPE html>
<html>
<head>
    <title></title>
    <meta charset="utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=edge">
    <meta name="viewport" content="width=device-width, initial-scale=1.0">
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css">
    <script src="http://js.arcgis.com/3.14/"></script>
    <link rel="stylesheet" href="http://maxcdn.bootstrapcdn.com/bootstrap/3.3.5/css/bootstrap.min.css">
    <script src="https://ajax.googleapis.com/ajax/libs/jquery/1.11.3/jquery.min.js"></script>
    <script src="http://maxcdn.bootstrapcdn.com/bootstrap/3.3.5/js/bootstrap.min.js"></script>
    <style>
        #gridDiv {
            height: 100%;
            width: 100%;
        #myModal {
            height: 100%;
            width: 100%;
        .modal-body {
            height: 300px;
    </style>
    <!-- HTML5 shim and Respond.js IE8 support of HTML5 elements and media queries -->
    <!--[if lt IE 9]>
      <script src="//cdnjs.cloudflare.com/ajax/libs/html5shiv/3.7/html5shiv.min.js"></script>
      <script src="//cdnjs.cloudflare.com/ajax/libs/respond.js/1.4.2/respond.min.js"></script>
    <![endif]-->
</head>
    <body class="claro">
        <form id="frmTest">
            <label id="lblOwnerAddress" for="ownerAddress">Owner's Address</label>
            <input type="text" id="ownerAddress" name="ownerAddress" value="111 S Main" />
            <div id="mainDiv" class="container">
                <!-- Modal -->
                <div class="modal fade" id="myModal" role="dialog">
                    <div class="modal-dialog">
                        <!-- Modal content-->
                        <div class="modal-content">
                            <div class="modal-header">
                                <button type="button" class="close" data-dismiss="modal">&times;</button>
                                <h4 class="modal-title">Select an Address</h4>
                            </div>
                            <div class="modal-body">
                                <div id="gridDiv"></div>
                            </div>
                            <div class="modal-footer">
                                <button type="button" class="btn btn-default" data-dismiss="modal">Close</button>
                            </div>
                        </div>
                    </div>
                </div>
            </div>
        </form>
        <script>
            var items
            require([
                    "dojo/on",
                    "dojo/_base/array",
                    "esri/tasks/locator",
                    "dojox/grid/DataGrid",
                    "dojo/data/ItemFileWriteStore",
                    "dijit/registry", "dojo/parser",
                    "dijit/registry",
                    "dojo/dom",
                    "dojo/_base/lang",
                    "dijit/layout/ContentPane",
                    "dojo/domReady!"
            function (on, arrayUtils, Locator, DataGrid, ItemFileWriteStore, registry, parser, registry, dom, lang) {
                parser.parse();
                var store, grid, data, layout, node;
                //document.getElementById("grid").style.display = "none";
                    console.log(node);
                    var params = {
                            data = {
                                identifier: "id",
                                items: []
                            layout = [[
                                    return result;
                                console.log(items);
                            if (window.grid) {
                                store: store,
                                structure: layout,
                                autoWidth: true,
                                autoHeight: false,
                                rowSelector: '20px'
                            // display grid
                            // Show modal
                            //hookup the event
                        else
                            alert("This does not appear to be an address in the city of Decatur. Please try again.");
                            dom.byId(node).focus();
                            dom.byId(node).value = "";
                                return x.address;
                    grid.startup();
                    console.log(evt);
        </script>
</body>
</html>
