Why can't I assign a layer to a value?
5445
6
05-13-2015 02:21 PM
ChrisSergent
I am trying to loop through layers and this block of code works:
 var jsonValue, signUrl, supportUrl;
    var restEndPoint = "http://maps.decaturil.gov/arcgis/rest/services/test/StreetSignTest/FeatureServer/";
    var config;
    // Get the id of a layer
    var requestHandle = esriRequest({
        url: "http://maps.decaturil.gov/arcgis/rest/services/test/StreetSignTest/FeatureServer/",
        content: {
            f: 'json'
        handleAs: "json"
    requestHandle.then(function (lyrJSON, io) {
        for (var i = 0; i < lyrJSON.layers.length; i++) {
            if (lyrJSON.layers.name = "Support") {
                jsonValue = lyrJSON.layers.id;
                supportUrl = restEndPoint + jsonValue;
        // app configuration
        config = {
            mapOptions: {
                showAttribution: false,
                sliderStyle: "small",
                extent: initialExtent,
                logo: false,
                sliderPosition: "bottom-right"
            signLayerUrl: "http://maps.decaturil.gov/arcgis/rest/services/test/StreetSignTest/FeatureServer/0",
            supportLayerUrl: supportUrl
        initMap();
But when I try to add the following code, I can't assign the value to signLayerUrl. I even tried to change i to t for the second if statement:
 var signValue, signUrl, supportValue, supportUrl;
    var config;
        content: {
            f: 'json'
        handleAs: "json"
                supportValue = lyrJSON.layers.id;
                supportUrl = restEndPoint + supportValue;
            if (lyrJSON.layers.name = "Sign") {
                signValue = lyrJSON.layers.id;
                signUrl = restEndPoint + signValue;
        config = {
            mapOptions: {
                logo: false,
            signLayerUrl: signUrl,
        initMap();
KenBuja
MVP Esteemed Contributor
Your "if" statements are incorrect. When comparing values, you have to use "===" (or "==" if you're not worried about comparing types in addition)
if (lyrJSON.layers.name === "Support") {
KenBuja
ChrisSergent
Thanks. I was evaluating the assignment. Felt stupid. Works great.
OwenEarley
Just a suggestion but you could also initialize the config object right at the start and then just assign the values to it. This just reduces the number of variables used and keeps things clean:
    var config = {
        mapOptions: {
            logo: false,
        signLayerUrl: undefined,
        supportLayerUrl: undefined
        url: restEndPoint,
        content: { f: 'json' },
        handleAs: "json"
            if (lyrJSON.layers.name == "Support") {
                config.supportLayerUrl = restEndPoint + lyrJSON.layers.id;
            if (lyrJSON.layers.name == "Sign") {
                config.signLayerUrl = restEndPoint + lyrJSON.layers.id;
        initMap();
EDIT - updated with the final function parenthesis and restEndPoint variable as Chris pointed out (just in case anyone copies the code block).
ChrisSergent
Awesome. It did need a trailing parenthesis and restEndPoint to be declared still, but you knocked out four variables for me. Thanks!
Here is my updated code for anyone that needs it:
    var config = {
        mapOptions: {
            logo: false,
        handleAs: "json"
        initMap();
OwenEarley
Apart from just reducing the number of variables you can use this as a namespace pattern to avoid possible variable collisions as the code base gets much larger. This keeps the variables that you declare isolated from variables that may be used in other third party code.
There is some really good info on this page - Essential JavaScript Namespacing Patterns
ChrisSergent
I added it on my toDo's for reading. Thanks.
