Where are the Javascript samples referenced in the tutorials?
4599
05-15-2015 12:36 PM
GerardoGarza
I was going through the JavaScript "Write a class" tutorial and found a bad link to the Seat Geek search.
http://servicesbeta.esri.com/demos/using-classes-with-javascript/AMD/seatgeek.html
I also found the link on the "Dojo and AMD" page.
Have these examples been relocated or is the site down?
ChrisSmith7
Honored Contributor
Not sure if this is helpful for your case, but here's a tutorial on classy js:
Writing a Class | Guide | ArcGIS API for JavaScript
thejuskambi
the question was about a broken link on that page
GerardoGarza
Thanks Chris.  I already went through that tutorial and do understand how to write a class now.
My issue is that the ESRI tutorial needs to be corrected if others are going to gain benefit from it.
ChrisSmith7
Honored Contributor
No problem, I wasn't sure if this tutorial would work for you since you were having resource problems on another one. Just thought I'd point out another one if it helped you at all.
