When Closing a Dojox Floating Pane - How to Reopen?
4187
05-01-2015 07:59 AM
IanPeebles
Hello everyone!  I am currently have an application that uses floating panes.  I have a main toolbar that contains the tool icons.  When a button is clicked, the floating pane will appear with the tool.  However, when I close the floating pane, then click on the button to re-activate, the floating pane will not re-appear.  I have read that closing the floating pane destroys the open.  Has anyone come up with the solution, so that each time you close the floating pane, you can re-open by clicking on the button?  The code I have is simple, both the JavaScript and HTML which is posted below.  What modifications do I need to make?  I appreciate any feedback.  Thank you.
Here is an example for a measuring tool:
JavaScript Code
// Hide Measuring Tool Floating Pane on Load
domStyle.set("measuringToolFloatingPanePick", "visibility", "hidden");
// Measuring Tool activate Floating Pane on Click
registry.byId("measuringToolButton").on("click", function () {
    openMeasuringToolFloatingPane("measuringToolFloatingPanePick");
// Open Measuring Tool using Floating Pane Function
   function openMeasuringToolFloatingPane(paneId) {
      var mtfp = registry.byId(paneId);
   mtfp.show();
// Measuring Tool
var measurementWidget = new Measurement({
   map: map,
   defaultAreaUnit: esri.Units.SQUARE_FEET,
   defaultLengthUnit: esri.Units.FEET
}, dom.byId("measurementDIV"));
measurementWidget.startup();
HTML Code
<!-- Measuring - Measuring Tool -->
   <div id="measuringFrame">
      <div data-dojo-type="dijit/form/Button" id="measuringToolButton" title="Measuring" data-dojo-props="iconClass:'measuringIcon'"></div>
   </div>
Here is how my floating pane appears.  It appears when clicking on the icon (within the red square).  When I close, then try to re-open...it won't.
KenBuja
MVP Esteemed Contributor
Take a look at this thread that has some alternative ways to deal with this.
