What's the deal with getScale()?
2638
6
08-24-2012 02:34 AM
BenFousek
I noticed the getScale() method has been added to the api reference, but is doesn't exist in a loaded DOM. Is it unimplemented at this point or is there an issue? I use .__LOD.scale. Which is easy enough, but a working getScale() method would be nice.
__Rich_
Do you mean esri.geometry.getScale?
__Rich_
BenFousek
esri.geometry.getScale(MAP_OBJECT) works, which is not a map object method, yet the api ref says it is.
__Rich_
Really?  I can't see it, but then, apparently, I never look for things properly!
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/map.htm
BenFousek
Right under getExtent().
[ATTACH=CONFIG]17219[/ATTACH]
The ref for getScale() is under "esri.geometry Namespace Methods". It's been around since v1.4. I suspect it was the proper place for it back when the map object was quite a bit simpler than it is now. Never stop learning, right?
__Rich_
Oh yeah, told you I didn't look properly!
I may be missing your point but...
.. it does say "Returns the current map scale. (As of v3.1)"
(and it does exist in 3.1, I've checked)
BenFousek
Yep it's there in 3.1. First thought was v was set to 3.0 but it is 3.1. Not sure why I was having issues the other day.
