What is the max number of records for a query?
4625
6
07-16-2015 07:59 PM
ChrisSergent
I want to restrict what a user can enter into a form field. I could have over 80,000 values for street addresses, but I would like to query and use an autocomplete to make it easier on the user while restricting what they enter. Is a queryTask capable of this?
thejuskambi
QueryTask is limited by the configuration on the service. The most Ideal would be to let user enter atleast 3 charaters without trying to get auto complete values. When you have the first 3 Character, your result will be greatly reduces from 80000 to a couple of thousands and it would be easier to display them as suggestions.
Hope this helps.
PS: I would have some rest service to get me the values only.
JoshHevenor
Without knowing your use, it sounds like you could consider using a geocoder and the new search dijit.
Search | API Reference | ArcGIS API for JavaScript
ChrisSergent
I do plan on using a geocoder. It's so that we can verify addresses that users enter are valid to eliminate manual verification.
JoshHevenor
Just to clarify for me, this is for some data entry form and not for navigation.  I assume you want to do a form with fields like addr_nbr, street_name, street_type, city, state, zip, etc., but use a filtering select on the street_name and street_type fields?
ChrisSergent
I uploaded the project. There is a just an address field, but several.
csergent45/codeViolationNotice · GitHub
JoshHevenor
The best way to post an example. Thanks! Got busy, but I'll have a look.
