What is the equivalent of a FloatingPanel control
1161
01-02-2013 02:31 PM
JoseSanchez
Hi all
In Dojo how do you use to replace the old Web ADF FloatingPanel control?
thanks
JakeSkinner
Esri Esteemed Contributor
Hi Jose,
I believe the 'dojox.layout.FloatingPane' is similar.  Here is an example:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=7" />
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title></title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/esri/css/esri.css">
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/dojo/dojox/layout/resources/FloatingPane.css">
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/dojo/dojox/layout/resources/ResizeHandle.css">
    <link rel="stylesheet" href="css/claro.css" type="text/css" media="screen" title="no title" charset="utf-8"/>
    <script type="text/javascript">var dojoConfig = {parseOnLoad: true};</script>
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.2"></script>
        dojo.require("dijit.layout.BorderContainer");
        dojo.require("dijit.layout.ContentPane");
        dojo.require("dojox.layout.FloatingPane");
        dojo.require("esri.map");
        var map;
        function init() {
            var initialExtent = new esri.geometry.Extent({"xmin":-8396836.868209211,"ymin":4835062.442691721,"xmax":-8328196.416809216,"ymax":4891396.53253782,"spatialReference":{"wkid":102100}});
            map = new esri.Map("mapDiv", {extent: initialExtent})
            var baseMap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer");
            map.addLayer(baseMap);
            dojo.connect(map, "onLoad", function(theMap){
                dojo.connect(dijit.byId('mapDiv'), 'resize', map, map.resize);
        function showMap() {
          if (!map) {
              init();
        dojo.addOnLoad(init);
    </script>
  </head>
  <body class="claro">
   <div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline'"  style="width: 100%; height: 100%; margin: 0;">
    <div id="floater" dojoType="dojox.layout.FloatingPane"  title='Map' dockTo="dock" closable="false" resizable="true"  dockable="true" >
      <div id="mapDiv" data-dojo-type="dijit.layout.ContentPane" style="height:100%;width:100%;">
          <input type="button" value="Show Map" onclick="showMap()" />
      </div>
    </div>
   </div>
  </body>
</html>
