Variables Javascript
7444
15
04-23-2015 02:45 PM
RickeyFight
I am looking for a way to add two variables together into a string.
My two variables are
var defExp = "SUB_REGION='East North Central'";
var defExp2 = "STATE_NAME IN( 'New York', 'New Jersey', 'Delaware')";
I need them to stay separate until they are in:
states.setDefinitionExpression(defExp OR defExp2);
I know this works:
var  defExp = "SUB_REGION='East North Central' OR STATE_NAME IN( 'New York', 'New Jersey', 'Delaware')";
states.setDefinitionExpression(defExp);
But I need two separate variables.
Thank you
RickeyFight
Robert,
Right now my code:
   //setup click event for buttons
                 query("select").forEach(function (node) {
                     on(node, "click", function (e) {
                     var target = e.target || e.srcElement;
                         switch (target.value) {
               case "0":
                defExp = "crime ='Larceny/Theft'";
                break;
              case "1":
                defExp =  "crime ='Vehicle Theft'";
                break;
              case "2":
                defExp ="crime ='Assult'";
                break;
              case "6":
                defExp ="crime ='Other'";
                break;
              case "7":
                defExp ="crime ='DUII'";
                break;
              case "8":
                defExp ="crime ='Fraud'";
                break;
              case "9":
                defExp ="crime ='Burglary'";
                break;
              case "Clear":
                defExp = "";
                break;
              case "3":
                defExp2 = "Month='August'";
                break;
              case "4":
                defExp2 =  "Month='July'";
                break;
              case "5":
                defExp2 = "Time_1 >= '1:00' AND Time_1 <= '5:00'";
                break;
              case "Clear2":
                defExp2 = "";
                break;
            var fDefExpr = (defExp !== "") ? ((defExp2 !== "") ? defExp + " AND " + defExp2 : defExp) : ((defExp2 !== "") ? defExp2 : "");
            lLayer.setDefinitionExpression(fDefExpr);
                         console.log((defExp !== "") ? ((defExp2 !== "") ? defExp + " AND " + defExp2 : defExp) : ((defExp2 !== "") ? defExp2 : ""));
I have two drop downs that can be chosen from. I am looking for three options that can be used together or independently.  Basically adding a defExp3
Thank you!
RobertScheitlin__GISP
Rickey,
  OK use this then:
            defArr = [];
            if(defExp !== ""){
              defArr.push(defExp);
            if(defExp2 !== ""){
              defArr.push(defExp2);
            if(defExp3 !== ""){
              defArr.push(defExp3);
            states.setDefinitionExpression(defArr.join(" AND "));
RickeyFight
Robert,
This is perfect because I can easily add more! I now have 4.
One issue I am having is that each drop down has to be "touched" for the filters to start working.
Here is a demo of my problem. demo3
Rickey,
   Your code is only setting the layer definition using the on click of the selects. You need to setup the initial values of the defExp, defExp2, defExp3, defExp4 in your widget and then apply those in your startup.
JakeSkinner
Esri Esteemed Contributor
Hi Rickey,
I would suggest using check boxes.  It seems you want to set a definition expression based on two expression.  Ex:
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10">
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <title>Feature Layer - display results as an InfoWindow onHover</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.6/js/dojo/dijit/themes/tundra/tundra.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.6/js/esri/css/esri.css">
    <style>
      html, body, #mapDiv {
        padding:0;
        margin:0;
        height:100%;
      #mapDiv {
        position: relative;
      #buttons {
        background: #fff;
        box-shadow: 0 0 5px #888;
        left: 1em;
        padding: 0.5em;
        position: absolute;
        top: 1em;
        z-index: 40;
    </style>
    <script src="http://js.arcgis.com/3.6/"></script>
    <script>
      var map, dialog;
      var defExp, defExp2;
      require([
        "esri/map", "esri/layers/FeatureLayer",
        "esri/symbols/SimpleFillSymbol", "esri/symbols/SimpleLineSymbol",
        "esri/renderers/SimpleRenderer", "dojo/query", "dojo/on", "dojo/dom"
      ], function(
        Map, FeatureLayer,
        SimpleFillSymbol, SimpleLineSymbol,
        SimpleRenderer, query, on, dom
        map = new Map("mapDiv", {
          basemap: "streets",
          center: [-80.94, 33.646],
          zoom: 4,
          slider: false
        var states = new FeatureLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/5", {
          mode: FeatureLayer.MODE_SNAPSHOT,
          outFields: ["STATE_NAME", "POP2000", "POP2007", "POP00_SQMI", "POP07_SQMI"]
        states.setDefinitionExpression("STATE_NAME = 'South Carolina'");
        var symbol = new SimpleFillSymbol();
        states.setRenderer(new SimpleRenderer(symbol));
        map.addLayer(states);
        on(dom.byId("EastCoast"), "click", function(){
          dom.byId("ENCentral").checked = false;
        on(dom.byId("ENCentral"), "click", function(){
          dom.byId("EastCoast").checked = false;
        on(dom.byId("SQMI"), "click", function(){
          dom.byId("AVE_FAM_SZ").checked = false;
          dom.byId("PopMil").checked = false;
        on(dom.byId("AVE_FAM_SZ"), "click", function(){
          dom.byId("SQMI").checked = false;
        on(dom.byId("PopMil"), "click", function(){
        on(dom.byId("execute"), "click", function(){
          query("input").forEach(function(node){
            if(node.id == "EastCoast"){
               if (dom.byId(node.id).checked){
                 defExp = "SUB_REGION='Middle Atlantic' AND STATE_NAME IN( 'New York', 'New Jersey', 'Delaware')";
            else if(node.id == "ENCentral"){
            else if(node.id == "SQMI" && dom.byId(node.id).checked){
                defExp2 = "SQMI>20000";
            else if(node.id == "AVE_FAM_SZ" && dom.byId(node.id).checked){
                defExp2 = "AVE_FAM_SZ<3";
            else if(node.id == "PopMil" && dom.byId(node.id).checked){
                defExp2 = "POP2007>1000000";
          console.log(defExp + " AND " + defExp2);
          states.setDefinitionExpression(defExp + " AND " + defExp2);
    </script>
  </head>
  <body class="tundra">
    <div id="mapDiv">
      <div id="buttons">
        <input type="checkbox" id="EastCoast"/>East Coast
        <input type="checkbox" id="ENCentral"/>EN Central<br>
        <input type="checkbox" id="SQMI"/>SQMI
        <input type="checkbox" id="AVE_FAM_SZ"/>Average Family Size
        <input type="checkbox" id="PopMil"/>Population<br>
        <input type="button" value="Execute" id="execute"/>
      </div>
    </div>
  </body>
</html>
RickeyFight
I cannot mark one as correct, they both were helpful!
How would I add to the script to show the number of states visible?
