Using token based secured services
2076
09-04-2013 12:15 PM
YimanSong
New to JS
How do I embed credentials in order to use a secured service? Can anyone provide samples on how to use IdentityManagerBase?
KenBurcham
What I tend to do is just append the token to the end of my service urls:
http: // data.yourdomain.com/arcgis/rest/services/SomeMapService/MapServer/0?token=AREALLYLONGSTRING
This works fine, but with the down-side that said url (and token) will be available to view from the client.  However, when I generate my token, I use the http referrer method, which means the token is useless unless coming from my own server folder.  But as John said above, the proxy method works great, too (and is required when doing things like feature editing).
ken.
JohnGravois
if you want to enable users to access secure services without signing in, one valid approach is to use a proxy to hide the credentials or token.
YimanSong
How does token work, if it doesn't require proxy?
KenBurcham
ken.
