Using the Mouse wheel as expected in web application that contains a map
2413
10-23-2014 06:36 AM
DanMcCartney
I've got a tabbed UI on my web page, the last tab is an arcgis javascript map built with their API. The problem I'm having is that just adding the map and all of the esri / dojo libraries to the page has caused the mouse scroll wheel to be entirely hijacked by the map. I can't scroll down on any other pages using the mousewheel, and disabling it in the map doesn't seem to do any good.
I've done a bit of work trying to figure out how to unbind the mousewheel events but have had no luck. Basically I want the mousewheel to work as expected if they aren't on the map tab, and zoom in and out if they are on the map tab.
Has anyone had this issue before?
