Using the editor widget, is it possible to dynamically modify the attribute inspector
767
06-19-2013 05:00 PM
ThomasRoussell
I have an application that uses the editor widget to edit a layer which contains multiple types of water crossings (plastic culverts, steel culverts, steel bridges, wooden bridge, arches, etc.). Certain fields in the water crossing layer are required to be filled in based on the type of water crossing. For example diameter is required for culverts, rise is required for bridges. Based on the feature being created or updated, is it possible to dynamically modify the attribute inspector to display only the required fields?
