Using the default symbology of a map service (point layer), but changing the size?
921
05-14-2013 05:48 AM
BrettGreenfield__DNR_
I'm trying to incorporate a map service with point data into my web map, but the points are ridiculously huge.  Unfortunately, my organization doesn't host the service so I can't change it; I'm guessing the only way to do this is to create custom symbology.  The data is currently set up to be symbolized by unique values - which I want - but I don't want to have to create five custom symbols for each of the different unique values as that seems like a lot of excess, messy code.  Is there a simple way to override only the size of the points while leaving the rest of the symbology to the default of the map service?
