Using substring to query, show result in datagrid
1691
06-02-2011 12:46 AM
hayaticm
I have a spatial layer which is join with a table, therefore all the field name will be in substring like PAD.LP_PD.OBJECTID.
I have no issue to run query from the substring, but i am stuck at function to zoom to selected feature/polygon when user click a row in datagrid(result from query).
Below is the code:
//Zoom to the parcel when the user clicks a row
function onRowClickHandler(evt){
var OBJECTID = ("PAD.LP_PAD.OBJECTID");
var clickedTaxLotId = grid.getItem(evt.rowIndex).OBJECTID;
var selectedTaxLot;
dojo.forEach(map.graphics.graphics,function(graphic){
if((graphic.attributes) && graphic.attributes.OBJECTID === clickedTaxLotId){
selectedTaxLot = graphic;
return;
var taxLotExtent = selectedTaxLot.geometry.getExtent();
map.setExtent(taxLotExtent);
I have tried using this declaration:
var clickedTaxLotId = grid.getItem(evt.rowIndex).(PAD.LP_PAD.OBJECTID);
var clickedTaxLotId = grid.getItem(evt.rowIndex).valueOf(PAD.LP_PAD.OBJECTID);
but those two declaration will take the whole result in datagrid, not the exact selected row.
Please advice..
Suggestion is highly appreciated.
HemingZhu
Below is the code:
var selectedTaxLot;
return;
Please advice..
Try this: either change clickedTaxLotId = grid.getItem(evt.rowIndex).OBJECTID to clickedTaxLotId = grid.getItem(evt.rowIndex).OBJECTID[0], or loose up the comparsion graphic.attributes.OBJECTID === clickedTaxLotId to graphic.attributes.OBJECTID == clickedTaxLotId
hayaticm
Tried both..it does not working. Seems like does not know/understand OBJECTID because the field is called PAD.LP_PAD.OBJECTID. if no substring used (spatial does not join with other table), then I can use OBJECTID only
HemingZhu
You can look at your service directory to see how the field names are listed. if the field listed as PAD.LP_PAD.OBJECTID, then the statement should be  clickedTaxLotId = grid.getItem(evt.rowIndex).PAD.LP_PAD.OBJECTID[0]. the best way to find out is to debug the statement.
hayaticm
Thanks for your advice, have to try to debug the code.
