using stored procedure to get selection
879
12-22-2011 11:48 AM
SaraSecunda
I would like to use an Oracle stored procedure to get a selection set from an attribute table of State data.  I would then like to use this to get the selection from the States layer and relate the attributes.  Is this possible with Javascript?  I know the result from the stored procedure is a datatable which has to be done on the server side.
SaraS
