Use Webservices with Arcgis API
5288
15
09-26-2019 05:35 AM
kawishabbas
Hi
Any one can help to pick my mistakes in given code. In web console data is showing but it's not displaying on map.
<!DOCTYPE html>
<html>
  <head>
    <meta charset="utf-8" />
    <meta
      name="viewport"
      content="initial-scale=1,maximum-scale=1,user-scalable=no"
    <title>GeoJSONLayer - 4.12</title>
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
    </style>
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.12/esri/themes/light/main.css"
    <script src="https://js.arcgis.com/4.12/"></script>
    <script>
      require([
        "esri/Map",
        "esri/views/MapView",
        "esri/request",
        "esri/Graphic",
        "esri/geometry/Point",
        "esri/layers/FeatureLayer",
      ], function(Map, MapView, esriRequest, Graphic,Point, FeatureLayer) {
          const url ="http://localhost:5000"
           const map = new Map({
          basemap: "satellite",
        const view = new MapView({
          container: "viewDiv",
          center: [67.068037, 24.872328],
          zoom: 12,
          map: map
        const fields = [
          alias: "ObjectID",
          type: "oid"
          alias: "Name",
          type: "string"
          alias: "FAT",
          type: "string"
          alias: "Type",
          type: "string"
          alias: "DC",
          type: "string"
          alias: "ID",
          type: "string"
          alias: "POP",
          type: "string"
        const pTemplate = {
        title: "{title}",
        content: [
            type: "fields",
            fieldInfos: [
                fieldName: "Name",
                label: "Name",
                visible: true
                fieldName: "FAT",
                label: "FAT",
                visible: true
                fieldName: "Type",
                label: "Type",
                visible: true
                fieldName: "DC",
                label: "DC",
                visible: true
                fieldName: "ID",
                label: "ID",
                visible: true
                fieldName: "POP",
                label: "POP",
                visible: true,
                format: {
                  digitSeparator: true,
                  places: 0
        const dataRenderer = {
          type: "simple",
          symbol : {
                type: "simple-marker",
                color: "blue",
                outline: { // autocasts as new SimpleLineSymbol()
                    width: 0.5,
                    color: [0, 0, 0, 0.2]
         var options = {
          query: {
            f: "json"
          responseType: "json"
        esriRequest(url, options).then(webservice)
        function webservice(response){
           var graphicsArray = response.data.map(function(result){
            //console.log(result)
             var resultPnts = result.SHAPE.points.map(function(point){
             return new Point({
                x:point.x,
                y:point.y,
                spatialReference : result.SHAPE.srid
              var atts = {
                "ObjectID": result.OBJECTID,
                "Splitter": result.Splitter,
                "Comment": result.Comment,
                "Name": result.Name,
                "ID": result.ID,
                "Placement": result.Placement,
                "POP": result.POP
              var graArr = resultPnts.map(function(pnt){
               var markerSymbol = {
                    type: "simple-marker",  // autocasts as new SimpleMarkerSymbol()
                    color: [226, 119, 40]
                return new Graphic({
                  geometry:pnt,
                  symbol: markerSymbol,
                  attributes: atts
              return graArr
          //console.log(graphicsArray)
          const layer = new FeatureLayer({
            geometryType: "point",
            source: [graphicsArray],
            fields: fields,
            objectIdField: "ObjectID",
            renderer: dataRenderer,
            popupTemplate: pTemplate
          map.add(layer);
    </script>
  </head>
  <body>
    <div id="viewDiv"></div>
  </body>
</html>
kawishabbas
Robert,
There is no return in my console.log....
Can i use variable outSpatialReference in point object instead of result.SHAPE.srid..??
         const outSpatialReference = new SpatialReference({
            wkid: 32642
             return new Point({
                x:point.x,
                y:point.y,
              var atts = {
                "ID": result.ID,
                "POP": result.POP
              var projectedPoint = projection.project(pnt,outSpatialReference);
                var graphic = new Graphic({
                  geometry:projectedPoint,
                  attributes: atts
                console.log(graphic)
              return graArr
RobertScheitlin__GISP
Kawish,
   You want to project the points to the view.spatialReference (which will be 102100). Right now you are you are asking it to project to same WKDI as the data is already in...
Corrected code:
            wkid: view.spatialReference
Also Have you called
projection.load()
earlier in your code?
kawishabbas
Robert,
Full code is mentioned below. I received same error in my console
<!DOCTYPE html>
<html>
  <head>
    <meta
      name="viewport"
    <title>JSON</title>
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
    </style>
    <link
      rel="stylesheet"
    <script>
      require([
        "esri/Map",
        "esri/request",
        "esri/Graphic",
        "esri/geometry/projection",
        "esri/geometry/SpatialReference"
      ], function(Map, MapView, esriRequest, Graphic,Point, FeatureLayer, projection, SpatialReference) {
      projection.load()
      let url ="http://localhost:5000"
      let fields = [
          alias: "ObjectID",
          type: "oid"
          alias: "Name",
          type: "string"
          alias: "FAT",
          type: "string"
          alias: "Type",
          type: "string"
          alias: "DC",
          type: "string"
          alias: "ID",
          type: "string"
          alias: "POP",
          type: "string"
      let pTemplate = {
        title: "{title}",
        content: [
            type: "fields",
            fieldInfos: [
                fieldName: "Name",
                label: "Name",
                visible: true
                fieldName: "FAT",
                label: "FAT",
                visible: true
                fieldName: "Type",
                label: "Type",
                visible: true
                fieldName: "DC",
                label: "DC",
                visible: true
                fieldName: "ID",
                label: "ID",
                visible: true
                fieldName: "POP",
                label: "POP",
                visible: true,
                format: {
                  places: 0
      let dataRenderer = {
          type: "simple",
          symbol : {
                color: "blue",
                    width: 0.5,
      let map = new Map({
      let view = new MapView({
          zoom: 12,
          map: map
       let options = {
        query: {
          f: "json"
    let fetchData = () => esriRequest(url, options).then(response => response.data)
    let webservice = res => {
           let graphicsArray =  res.map(function(result){
             let resultPnts = result.SHAPE.points.map(function(point){
             return new Point({
                x:point.x,
                y:point.y,
              let atts = {
                "ID": result.ID,
                "POP": result.POP
              let graArr = resultPnts.map(function(pnt){
              let projectedPoint = projection.project(pnt,view.spatialReference);
               let markerSymbol = {
                  attributes: atts
                //console.log(graphic)
              return graArr
          let layer = new FeatureLayer({
          fields: fields,
        map.add(layer)
    view.when(() =>{
      fetchData()
      .then(webservice)
    </script>
  </head>
  <body>
  </body>
</html>
This is response of my data that i received in console..
I want to discuss one more thing. When i use geojson service(http://localhost:5000/geojson ) instead of json service(http://localhost:5000) the above code is working well. Why its not working on json service.
Result of geojson service.
Kawish,
   Looks like you problem most likely is your feature layer source.
You are wrapping the array in square brackets which means an array inside and array.
(line 3 square brackets removed).
  source: graphicsArray,
  fields: fields,
As for your other question I am not sure. based on the web console it seems the geojson endpoint is returning wkid 4326 instead.
kawishabbas
Thank you Robert,
error occurs because of an array inside and array. I create an empty array with name myData and push graphic object into myData then call its instance in FeatureLayer. Its working well.
let myData = [];
let g =  new Graphic({
                  attributes: atts
                myData.push(g)
            source: myData,
            fields: fields,
Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
