Urgent help with hover-onclick!
3417
03-24-2011 12:37 AM
YuwonNg
Hi, I'm new & I need help as I'm stuck with the codes.
Basically, what I'm trying to do is to implement hover & onclick functions on an icon. When I mouse over an icon, the infoWindow will appear or user can choose to onclick on the infoWindow.
Here's the sample codes that I tried with:
    <script type="text/javascript">
        dojo.require("esri.map");
        dojo.require("esri.tasks.geometry");
        //dojo.require("esri.dijit.InfoWindow");
        var map=null;
        var topoMap=null;
        var levelNumber=1;
        var centerPoint="32173.834393929,29296.8452311538";
        var OneMap = new GetOneMap('map','SM',{level:levelNumber,center:centerPoint});
        function initialize() {
        try{
            map=OneMap.map;
            //handle map object here
            if( map ==null  )
                LogError("map not initialized");return;
            //dojo.connect(map, "onLoad", PlaceLabel);
            PlaceLabel();
        catch(err2){LogError(err2.message);}
        function PlaceLabel(evt) {
        map.graphics.clear();
        var strImage,symbol,pt,graphic,stX,stY,infoTemplate,json,g,cont,cont1,tit,lin;
        var icounter = 0;
stX             =   "23319.3347409758";
stY             =   "28825.7191286444";
tit = "TRY OUT";
cont = "abc";
lin= "www.onemap.com"
pt= new esri.geometry.Point(stX,stY,map.spatialReference);
cont1 = "Description:"+cont+ "<br/>Detail:"+lin;
strImage = "C:/Users/L33508/Desktop/images/fish.jpg";
symbol = new esri.symbol.PictureMarkerSymbol(strImage, 25,25);
json = {title:tit,content:cont1 };
infoTemplate = new esri.InfoTemplate(json);
graphic = new esri.Graphic(pt,symbol);
graphic.setInfoTemplate(infoTemplate);
map.graphics.add(graphic);
dojo.connect(graphic, "onClick", function(evt){
g = evt.graphic;
map.infoWindow.setTitle();
map.infoWindow.show(evt.screenPoint,map.getInfoWindowAnchor(evt.screenPoint));
map.infoWindow.resize(260,130);
dojo.addOnLoad(initialize);
    </script>
Here's the sample OneMap codes which I want to implement the above codes into:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
 <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
    <meta http-equiv="X-UA-Compatible" content="IE=7" />
    <title>OneMap-Add Map</title>
   <script type='text/JavaScript' src='http://www.onemap.sg/API/JS?accessKEY=xkg8VRu6Ol+gMH+SUamkRIEB7fKzhwMvfMo/2U8UJcFhdvR4yN1GutmUIA3A6r3LDhot215OVVkZvNRzjl28TNUZgYFSswOi'></script>
    <script language="JavaScript" type="text/JavaScript">
//    //add map with default settings
//    var OneMap = new GetOneMap('divMain','SM');
//    //add map with defined centerPoint
//    var centerPoint="28968.103,33560.969"
//    var OneMap = new GetOneMap('divMain','SM',{center:centerPoint});
//    //add map with defined zoom level
//    var levelNumber=8;
//    var OneMap = new GetOneMap('divMain','SM',{level:levelNumber});
//    //add map with layer
//    var myLayerService = "http://www.onemap.sg/ArcGIS/rest/services/POI/MapServer";
//    var myLayer = new esri.layers.ArcGISDynamicMapServiceLayer(myLayerService);
//    var OneMap = new GetOneMap('divMain','SM',{level:levelNumber,layer:myLayer,center:centerPoint});
    //add map with defined center location and zoom level
    var levelNumber=8;
    var OneMap = new GetOneMap('divMain','SM',{level:levelNumber,center:centerPoint});
function addMap() {
    OneMap.map.addLayer(myLayer);
function GetCurrentLevel() {
  alert ("Current Level:" + OneMap.map.getLevel())
  </script>
  </head>
  <body class="tundra">
  <table>
  <tr>
  <td>
  <div id="divMain" style='width:450px;height:450px;'></div></td>
  <td>Map navigation using mouse:
    <ul>
      <li>Drag to pan</li>
      <li>Mouse Scroll Forward to zoom in</li>
      <li>Mouse Scroll Backward to zoom out</li>
      <li>Use Arrow keys to pan</li>
      <li>Double Click to Center and Zoom in</li>
    </ul>
  </td>  </tr></table>
  <input id="Button1" type="button" style="width:150px" value="Add Map" onclick="addMap()" />
<input id="Button3" type="button" style="width:150px" value="Current Map Level" onclick="GetCurrentLevel()" />
    </body>
</html>
I've also attached a sample screenshot of a onclick version. However, I want both the onclick & hover.
Please help, thanks!
derekswingley1
I would encourage you to rethink this design. I would use onmouseover or onclick, but not both (and I would go with onclick).
From a practical standpoint, how are you envisioning this would work? For a user to click an icon, they have to mouse over it. It doesn't make sense to do the same thing for onmouseover and onclick.
YuwonNg
Hi, thanks for the reply! I have decided to use onclick as there would be multiple tabs in the infoWindow. (:
WarrenMedernach
So then how would you suggest the following design scenario:  I want a tooltip/maptip displayed automatically when a user hovers over a feature, but then I would like to enable them to edit the attributes by selecting (onclick) the feature?
Or are there better ways to accomplish this?
Thanks so much.
Warren M
