Upgrade API to 3.2 latest version.
1730
09-24-2012 08:56 PM
SunilPalkar
Hello All,
I am using Java script API 3.0 version on my machine and I want to upgrade it to 3.2.
How do I proceed ? I have gone through following article
"No need to download and re-install the API when new versions are released. You just need to modify the script tag in your application to point to the new version."
I have installed it on my local machine and using internal map services as base map.
Thanks in advance : )
SunilPalkar
Hi Stephen,
You are simply great !!! ...Thanks for your prompt reply !!!
Thank you : )
Hi Steve,
In your HTML there'll be a pointer to the API - update this to point to the 3.2 version:
 <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.2"></script>
Steve
StephenLead
Honored Contributor
Hi Steve,
Steve
SunilPalkar
Hi Stephen,
Thank you : )
Hi Steve,
Steve
derekswingley1
You'll also want to add a <link> tag for esri.css. This is new with 3.2:
<link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/esri/css/esri.css">
More info here:  http://help.arcgis.com/en/webapi/javascript/arcgis/help/jshelp/css.htm
SunilPalkar
Dear Derek,
Good Morning,
Thanks for the reply...one small sub-question...is there any getting started material for this API ?  I am new beginner  for this Java Script API ( I am familiar to Server and Desktop 10.0)
Also I found that many people (Even I am also) customizing the sample code and using in our applications is that a correct way to get start ?
Support person told me that start doing customization ..Is this best way to get start..is that true ?
As always your support is the outstanding  in the world.. hats off to you all : )
Thanks a lot for replying to my question.. have a nice day !!!
derekswingley1
Take a look at the "Getting Started" section of our conceptual help:  http://help.arcgis.com/en/webapi/javascript/arcgis/help/jshelp_start.htm
Downloading and modifying the samples is also a good way to get started.
Thanks!
