Update Workflow in Editor Widget Issue
9262
22
08-13-2023 11:12 PM
MohammedZaki
I'm using the editor widget, JS SDK version 4.27.6
The update button is not working.
- Clicking the button is not triggering any HTTP requests or doing any actions.
- No errors in the console.
Is this a common bug?
NicolasSwijngedouw
I'm encountering the same issue here. Have you found a solution to this problem?
Kind regards,
Nicolas
NicolasSwijngedouw
I was able to fix it by rolling back to version 4.24. Not ideal but the bug is not documented at this point. I'm not sure if it has been reported yet.
MarcRamser
Same problem here. Looks like the bug was introduced between 4.26.5 and 4.27.1
AlfredoDeLaAsuncion
I am encountering the same problem with the ArcGIS API Editor widget for JavaScript version 4.27.0. Like you, when I click the update button, no HTTP request is initiated and no action is taken.
Here are a few things I have checked so far:
Making sure the layers have editing enabled on the server side.
I'm still working on the problem, but I was wondering if you've had any success since your post. If you've found a solution, I'd love to hear about it.
MarcRamser
No, we decided to not upgrade for now... Hope it gets fixed soon.
KyleONeill
I'm having the same issue. I did just realize the editor works in Firefox but not in Chrome (which is what I normally use for development) -- is that the same for you all, and has anyone found a fix?
SergioSalmeron_NTT
I see that this topic is stopped, any solution?
AGILHAGI
Same thing for me. Moved to Firefox until this issue is fixed.  The samething  appears with the compass. It works fine in Firefox, but it can out of nowhere stop working in chrome and Edge.
AGILHAGI
The solution for me currently is that it works fine in Firefox bot not in chrome or Microsoft Edge.
