Update Feature Error
5725
22
05-22-2019 05:28 AM
NadirHussain
Dear all,
 i am trying to update a feature using feature service.My geodatabase is versioned.below is my code
var UpdateAttr = {
اسم_الشركة: test_2,
Mineral :validFeature.attributes.Mineral,
Geologist : validFeature.attributes.Geologist,
Duration : validFeature.attributes.Duration,
End_Date : validFeature.attributes.End_Date,//"",
Decision_Type :validFeature.attributes.Decision_Type,//"",
Decision_Date : validFeature.attributes.Decision_Date,//"",
Decision_No : validFeature.attributes.Decision_Date,//"",
Visible_Code :validFeature.attributes.Visible_Code,//"",
Emirat_Code : validFeature.attributes.Emirat_Code,//
Mineral_Code : validFeature.attributes.Mineral_Code,//"",
Complex_Code : validFeature.attributes.Complex_Code,//"",
City_Code :validFeature.attributes.City_Code,//"",
Status_Code :validFeature.attributes.Status_Code,
Emirate : validFeature.attributes.Emirate,*/
Governorate : "ddd",
var UpdateValidLayer = new esri.layers.FeatureLayer(featureServiceValidURl);
var MyUpdateGraphic = new esri.Graphic(null, null, UpdateAttr);
var updateFeatures = [];
updateFeatures.push(MyUpdateGraphic);
UpdateValidLayer.applyEdits(null, updateFeatures, null, function (addResults, updateResults, deleteResults) {
  dynamicMapServiceLayer.refresh();
  console.log("Apply Edits Successfully:");
  alert("updated Successfully");
}, function (err) {
alert(err.message+"___"+err.code+"_________"+err.id);
console.log("Apply Edits Failed: ",err.message+err.code);
Always through error "Unabale to complete operation.Error Code is 400".i have this code many times in my other projects.But this time throwing error.
i also try to update feature using arcgis server webinterface.it works from the webinterface.so
Pls help.Thanks is advance.
RobertScheitlin__GISP
Nadir,
  Have you verified that validFeature is not null and is a graphic?
NadirHussain
 Dear Robert,
 i check validfeature is not null and i replace this staetment with
var feature = new esri.Graphic(null, null, UpdateAttr);
i also check feature is not null.
Nadir,
  Remember I told you that would not work because you are trying to update so you need the original features ObjectId and geometry.
NadirHussain
Robert,
  i tried with both ways.But its not work.
  var graphic=validFeature weather this statment is right or wrong but not throwing any error
Nadir,
   I am lost then. When updating features in a FeatureService I just get the graphic (feature) I am updating and make my change to the attributes or geometry and then add that graphic to an array and pass that array to the update portion of applyEdits and it works.
NadirHussain
Robert,
 Can you share your code so that i can match and figure out where is i am making mistake.
Thanks for your cooperation
        var graphic = polyFeatLayer.graphics[polyFeatLayer.graphics.length - 1];
        var currentDate = new Date();
        var dateString = ((currentDate.getMonth() + 1) + "/" + currentDate.getDate() + "/" + currentDate.getFullYear());
        var fixedDate = new Date.parse(dateString);
        graphic.attributes["DT_ADDED"] = fixedDate;
        polyFeatLayer.applyEdits(null, [graphic], null);
NadirHussain
Dear Robert,
   the above code also not work.i think some problem in the code given below which i am using
    var queryTask = new esri.tasks.QueryTask(RestServiceUrl + "/0");//Query For Valid Licences
var query = new esri.tasks.Query();
query.returnGeometry = true;
query.outFields = ["*"];
query.where = "OBJECTID = '" + strLicsNumber + "'";
queryTask.execute(query, function (resultset) {
if(resultset.features.length>0){
validFeature = resultset.features[0]; ---->i am getting the feature here this line is right or wrong
updateValidFeature(validFeature ,strHello,strHello1);
function updateValidFeature(validFeature,strHello,strHello1){
try {
if(validFeature!=null){
alert("ff");
validFeature["DISTANCE "]="100.00";
UpdateValidLayer.applyEdits(null,[validFeature],null, function (addResults, updateResults, deleteResults) {
console.log("Apply Edits Successfully:", updateResults);
}, function (err) {
alert(err.message+"_________"+err.code+"_________"+err.details+"_______"+err);
console.log("Apply Edits Failed: ",err);
catch(Ex){
alert(Ex.message);
pls check.
Nadir,
   Is the distance field a string type?
NadirHussain
Robert,
its double.But i already changed in my code.the fallowing error coming
Cannot read property 'attributes' of undefined.
what is undefined in this small code.this make me crazy
