UniqueValueRenderer - multiple attribute rendering?
9560
11
03-12-2012 12:16 PM
evanpicard
This -
esri.renderer.UniqueValueRenderer(defaultSymbol, attributeField, attributeField2?, attributeField3?, fieldDelimeter?)
Creates a new UniqueValueRenderer object. Typically features are rendered based on the unique values of one attribute field. However up to three fields can be combined to generate a unique value. For example, if two fields are used which store the values A and B; and X, Y, and Z respectively, then the unique values for the renderer can be A:X, A:Y, A:Z, B:X, B:Y and B:Z, assuming ":" is the field delimiter.
would lead me to believe that this -
var salesRepsRend = new esri.renderer.UniqueValueRenderer (new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_CROSS, 10, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 1), new dojo.Color([0,255,0,0.25])),"PCText", "Ldr_type", "Name" ":");
salesRepsRend.addValue("0:0", new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE, 10, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 1), new dojo.Color([0,255,255,0.25])));
salesRepsRend.addValue("1:0", new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_X, 10, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 1), new dojo.Color([0,255,255,0.25])));
salesRepsRend.addValue("0:1", new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE, 10, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 1), new dojo.Color([0,255,255,0.25])));
should work.  which is not the case.
I'm really only interested in rendering based on 2 fields, PCText and Ldr_type, but I get "esri.layers.FeatureLayer: unable to find ':' field in the layer 'fields' information [url: " if i don't fill in the third attribute.
so my problem is that it doesnt render uniquely, everything renders with the default renderer.
Any ideas?
Evan
shwetasharma
sorry for not posting the code before...
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml"
      xmlns:h="http://java.sun.com/jsf/html"
      xmlns:f="http://java.sun.com/jsf/core">
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
    <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9"/>
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>
      Unique Value Renderer
    </title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.8/js/dojo/dijit/themes/claro/claro.css"/>
    <script type="text/javascript">
      var djConfig = {
        parseOnLoad: true
    </script>
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.8">
    </script>
    <script type="text/javascript" charset="utf-8">
      dojo.require("esri.map");
      dojo.require("esri.layers.FeatureLayer");
      var map;
      //var ddname=Beed;
      function init() {
        map = new esri.Map("map", {
          extent:new esri.geometry.Extent({"xmin":69.84,"ymin":15.05,"xmax":82.98,"ymax":22.26,"spatialReference":{"wkid":4326}}),
          slider: false
        dojo.connect(map, "onLoad", initOperationalLayers);
        map.addLayer(new esri.layers.ArcGISDynamicMapServiceLayer("http://mrsacgis1/ArcGIS/rest/services/Planning/rdd/MapServer"));
      function initOperationalLayers() {
        var defaultSymbol = new esri.symbol.SimpleFillSymbol().setStyle(      esri.symbol.SimpleFillSymbol.STYLE_NULL);
        defaultSymbol.outline.setStyle(esri.symbol.SimpleLineSymbol.STYLE_NULL);
        //create renderer
        var renderer = new esri.renderer.UniqueValueRenderer(defaultSymbol, "SDE.village_mosaic.DIST_NAME","SDE.SECTOR_RDD.PERE_RD","");
        //add symbol for each possible value
        renderer.addValue("Pune:0", new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([255, 0, 0, 1])));
        renderer.addValue("Pune:1", new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([0, 0, 0, 1])));
        renderer.addValue("Pune:2", new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([0, 0, 255, 1])));
        var featureLayer = new esri.layers.FeatureLayer("http://mrsacgis1/ArcGIS/rest/services/Planning/rdd/MapServer/2", {
          mode: esri.layers.FeatureLayer.MODE_SNAPSHOT,
          outFields: ["SDE.village_mosaic.DIST_NAME","SDE.SECTOR_RDD.PERE_RD"]
        featureLayer.setRenderer(renderer);
        map.addLayer(featureLayer);
      dojo.addOnLoad(init);
    </script>
  </head>
  <body>
    <div id="map" class="claro" style="width:1000px; height:800px; border:1px solid #000;">
    </div>
  </body>
</html>
Here SDE.village_mosaic.DIST_NAME field is string and SDE.SECTOR_RDD.PERE_RD is integer.
I am using this link as reference:
  http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples_start.htm#jssamples/renderer_uniqu...
The only difference is i am using ArcGISDynamicMapServiceLayer instead ArcGISTiledMapServiceLayer but it is working fine for a single field.
i am new in this field plz help....
evanpicard
I *think* the problem is you've got a blank "" for your delimeter, but you've got ":" in your addvalue statements.
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/uniquevaluerenderer.htm#fieldDelimiter
try this:
        var renderer = new esri.renderer.UniqueValueRenderer(defaultSymbol, "SDE.village_mosaic.DIST_NAME","SDE.SECTOR_RDD.PERE_RD", null, ":");
Let us know if it works.
and if it does, please check this as an answer, it would be my first!
Evan 🙂
