unique value function
1901
12-05-2016 02:26 PM
ChristianSailer2
Simple question:
How do you get unique values (for instance for rendering or calculate statistics) from a feature service where the value can change dynamically?
Tags (1)
RobertScheitlin__GISP
Christian,
   You can use a Query on the layer using returnDistinctValues property of the Query class in the JS API.
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Query distinct values without map</title>
    <script src="https://js.arcgis.com/3.18/"></script>
    <script>
      require([
        "dojo/dom", "dojo/on",
        "esri/tasks/query", "esri/tasks/QueryTask", "dojo/domReady!"
      ], function (dom, on, Query, QueryTask) {
        var queryTask = new QueryTask("https://services.arcgis.com/V6ZHFr6zdgNZuVG0/arcgis/rest/services/Puget_Sound_BG_Food/FeatureServer/...");
        var query = new Query();
        query.returnGeometry = false;
        query.returnDistinctValues = true;
        query.outFields = [
          "COUNTY"
        on(dom.byId("execute"), "click", execute);
        function execute () {
          query.where = '1=1';
          queryTask.execute(query, showResults);
        function showResults (results) {
          var resultItems = [];
          var resultCount = results.features.length;
          for (var i = 0; i < resultCount; i++) {
            var featureAttributes = results.features[i].attributes;
            for (var attr in featureAttributes) {
              resultItems.push("<b>" + attr + ":</b>  " + featureAttributes[attr] + "<br>");
            resultItems.push("<br>");
          dom.byId("info").innerHTML = resultItems.join("");
    </script>
  </head>
  <body>
    <input id="execute" type="button" value="Get Details">
    <br />
    <br />
    <div id="info" style="padding:5px; margin:5px; background-color:#eee;">
    </div>
  </body>
</html>
Christian,
<!DOCTYPE html>
<html>
  <head>
    <script>
      require([
        query.outFields = [
          "COUNTY"
    </script>
  </head>
  <body>
    <br />
    <br />
    </div>
  </body>
</html>
ChristianSailer2
returnDistinctValues property! Ok, didn't think about! Thank you!
Don't forget to mark this question as answered by clicking on the "Correct Answer" link on the reply that answered your question.
