Unable to see images in arcgis-popup attachments in SDK 5
977
03-05-2026 11:52 AM
MKY
Image attachments are not showing in popup from a secured service. but clicking the link opens the image in a different tab.
If the additional parameters w&s are removed from img src, the image is visible.
Is there any work around?
LaurenBoyd
Hi @MKY -
Would you be able to provide more details about your configuration? I tried reproducing the issue, but haven't been able to see what you're experiencing.
It looks like the request to the service with the attachments has a proxy URL appended to it. Is this a secure layer with the credentials saved in the item and that layer is being loaded in your application? Can you also confirm that this was working with the widget?
Lauren
MKY
I have an asp .NET core proxy to handle secured services, and it works fine.  The proxy configuration has credentials. The problem happens on the widget too.
 "allowedReferrers": [ "*" ],
 "tokenCacheMinutes": 59,
 "serverUrls": [
     "url": "https://maps2.dcgis.dc.gov/dcgis/",
     "username": "ccccc",
     "password": "ccccc",
     "tokenUrl": "https://maps2.dcgis.dc.gov/dcgis/tokens/generateToken",
     "referer": "requestip",
     "useAppPoolIdentity": false
 I have a function to manually upload attachments.
 private _uploadAttachment(feature: any) {
           //create form
            const attachmentForm = document.createElement("form");
            attachmentForm.setAttribute("id", "attachmentForm");
            attachmentForm.classList.add("esri-hidden");
            let fileSelector = document.createElement("input");
            fileSelector.setAttribute("id", "fileSelector");
            fileSelector.setAttribute("type", "file");
            fileSelector.setAttribute("name", "attachment");
            fileSelector.setAttribute("accept", "image/*,video/*,application/pdf,application/msword,text/plain");
            let entInput = document.createElement("input");
            entInput.setAttribute("name", "f");
            entInput.setAttribute("value", "json");
            attachmentForm.appendChild(fileSelector);
            attachmentForm.appendChild(entInput);
            document.body.appendChild(attachmentForm);
            document.getElementById('fileSelector')?.addEventListener("change", (e) => {
                let uploadedFile = (e.target as any).files[0];
                if (!uploadedFile) {
                    let message = "No file has been selected.";
                    this._errorDialogContent.innerHTML = message;
                    this._errorDialog.open = true;
                    return;
                //examine file if there is a size requirement
                let result: any = this._validateUploadFile(uploadedFile);
                if (!result.isValidFile) {
                    this._errorDialogContent.innerHTML = result.msg;
                    return;
                let reader = new FileReader();
                reader.onload = (event) => {
                    const arrayBuffer = (event.target as any).result;
                    const byteArray = new Uint8Array(arrayBuffer); // Convert to Uint8Array
                    let blob = new Blob([byteArray], { type: uploadedFile.type });
                    this._addAttachments(feature, blob, uploadedFile.name, uploadedFile.type);
                reader.onerror = () => {
                    this.hideLoading();
                    this.showAlert("error", "Attachment upload has failed.", 5000);
                reader.onprogress = () => {
                    this.showLoading();
                reader.readAsArrayBuffer(uploadedFile);
            document.getElementById('fileSelector')?.click();
I useFeatureLayer.queryAttachments to show on a form the attachments with no problem.
In popup it looks like this
The only difference I see is that in the popup the image comes with additional parameters
Appreciate any help on this.
MKY
Is it possible to add a property to AttachmentQuery to control (disable) dynamic image resizing and scaling?
When using proxy and the w and s parameters prevent it from showing in the popup.
If there is a workaround, please post some samples
