Trying To Set Visible Layers By Check Boxes
2712
5
05-17-2014 01:34 PM
CharlesGant
Well made a little progress before hitting another road block. Trying to toggle visibility of n number of layers by check box.  The code below loads up fine, but I get a "visible[lc] is undefined" and "a.join is not a function" errors in the console.  I played around with it for about four hours and all I could get it to do what load both layers at the same time when clicking either check box.  Obviously, the check boxes need to be independent of one another.   I think the error lies in the for loops.  Did not testing and it has the correct number for "layers", and also for "il".  What am I missing?
Also, not sure if this "imageParameters.layerIds = [0,1,2];" is correct?  I have the webmap loaded, then two layers on top, shouldn't that be correct with an index of "0"?
  <script src="http://js.arcgis.com/3.9/"></script>
  <script>
    require([
   "esri/map",
   "dojo/parser",
   "dojo/ready",
   "dijit/layout/BorderContainer",
   "dijit/layout/ContentPane",
   "dojo/dom",
   "dojo/on",
   "dojo/query",
   "esri/layers/CSVLayer",
   "esri/Color",
   "esri/symbols/SimpleMarkerSymbol",
   "esri/renderers/SimpleRenderer",
   "esri/InfoTemplate",
   "esri/urlUtils",
   "esri/arcgis/utils",
   "esri/dijit/Legend",
   "esri/dijit/Scalebar",
   "esri/layers/ArcGISDynamicMapServiceLayer",
   "esri/layers/FeatureLayer",
   "esri/layers/ImageParameters",
   "dojo/domReady!"
    ], function(
   Map,
   parser,
   ready,
   BorderContainer,
   ContentPane,
   dom,
   on,
   query,
   CSVLayer,
   Color,
   SimpleMarkerSymbol,
   SimpleRenderer,
   InfoTemplate,
   urlUtils,
   arcgisUtils,
   Legend,
   Scalebar,
   ArcGISDynamicMapServiceLayer,
   FeatureLayer,
   ImageParameters
   ready(function(){
   parser.parse();
   var visible = [] ,layers = [];
   arcgisUtils.createMap("964718e320ea4fc4abcc73ada068d015","map").then(function(response){
     //update the app
   var map = response.map;
   //Use the ImageParameters to set the invisible layers in the map service during ArcGISDynamicMapServiceLayer construction.
   var imageParameters = new ImageParameters();
   imageParameters.layerOption = ImageParameters.LAYER_OPTION_HIDE;
   //can also be: LAYER_OPTION_EXCLUDE, LAYER_OPTION_HIDE, LAYER_OPTION_INCLUDE
   //Takes a URL to a non cached map service.
   var dynamicMapServiceLayer1 = new ArcGISDynamicMapServiceLayer("http://gis.srh.noaa.gov/ArcGIS/rest/services/RIDGERadar/MapServer", {
      "opacity" : 0.5,"imageParameters":imageParameters});
   var dynamicMapServiceLayer2 = new ArcGISDynamicMapServiceLayer("http://gisdev.srh.noaa.gov/arcgis/rest/services/GSP/gffg/MapServer", {
   map.addLayer(dynamicMapServiceLayer1);
   layers.push(dynamicMapServiceLayer1);
   map.addLayer(dynamicMapServiceLayer2);
   layers.push(dynamicMapServiceLayer2);
   on(dom.byId("layer1CheckBox"), "change", updateLayerVisibility);
   on(dom.byId("layer2CheckBox"), "change", updateLayerVisibility);
     // var csv = new CSVLayer("./data/180query.csv");
     // var orangeRed = new Color([238, 69, 0, 0.5]); // hex is #ff4500
     // var marker = new SimpleMarkerSymbol("solid", 15, null, orangeRed);
     // var renderer = new SimpleRenderer(marker);
     // csv.setRenderer(renderer);
     // var template = new InfoTemplate("${lid}", "${name}");
     // csv.setInfoTemplate(template);
     // map.addLayer(csv);
   //Sets up the ability for dynamicMapServiceLayers to be toggled.
   console.log(layers)
   function updateLayerVisibility() {
    var lc = 0;
    var li = 0;
    var inputs = dojo.query(".list_item"), input;
    visible = [];
    for (var i=0, il=inputs.length; i<il; i++) {
     if(i>=li+layers[lc].layerInfos.length) {
      lc++;
      li=i;
     if (inputs.checked) {
      visible[lc].push(inputs.id-li);
    for (var t=0, tl=layers.length; t<tl; t++)
     layers.setVisibleLayers(visible);}
  </script>
CharlesGant
After nearly another twelve hours of code combinations, nothing.  My project currently entails only two map services with only one layer in each, however that might not always be the case.  Thus, I would like to build one updateLayerVisibility () function to do it all.  Can anyone help?  Thanks!!!
CharlesGant
LoriGonzalez
How are your checkboxes setup? Can you post the HTML?
Also, have you tried using the TOC control. I think it has all the functionality you are looking for.
http://www.arcgis.com/home/item.html?id=9b6280a6bfb0430f8d1ebc969276b109
JordanPorter
This is how i did it
[PHP]
//Layers, these will be referenced later by their "id"
var A = new FeatureLayer("http://maphics:6080/arcgis/rest/services/Transportation/MapServer/4", {
            mode: FeatureLayer.MODE_SNAPSHOT,
            infoTemplate: TrafficTemplate,
            outFields: ["Name1", "AADT2011"],
            opacity: 0
        l
var B = new FeatureLayer("http://maphics:6080/arcgis/rest/services/Transportation/MapServer/6", {
            opacity: 0
//create a checkbox for each layer (referencing their IDs), that when pressed will toggle show/hide
arrayUtils.forEach(["Layer1", "Layer2"], function(id){
            new CheckBox({
                id: "cb_" + id,
                name: "cb_" + id,
                checked: false,
                onChange: function(bool){
                    bool ? map.getLayer(this.id.split("_")[1]).show() : map.getLayer(this.id.split("_")[1]).hide();
            }, domConstruct.create("input", {
                id: "lyr_" + id
            })).placeAt(dom.byId("layerToggle"));
            // create a label for the check box
            var label = domConstruct.create('label', {
                "for": "cb_" + id,
                "id": "lbl_" + id,
                "innerHTML": id
            domConstruct.place(label, dom.byId("layerToggle"));
            domConstruct.place(domConstruct.create("br"), dom.byId("layerToggle"));
        });[/PHP]
CharlesGant
I will look into the TOC widget and see if I can get that working the way I desire.  If not, I'll be back. LOL.  Then will attach my code.  Thanks!
