trying to add map service layer
1302
05-29-2014 06:57 AM
jaykapalczynski
Honored Contributor
Trying to add map service layer and not working...thoughts?
Syntax?  Maybe because I am using FeatureLayer?  Using Server 10.1
Note:  Changed the Rest End point URL for this example
 // Warbler 1  var flWarbler1 = new ArcGISDynamicMapServiceLayer("https://fwisweb1.gov/arcgis/rest/services/Warbler_Map/Warbler_Map_Readonly/MapServer/0", {          mode: FeatureLayer.MODE_ONDEMAND,          outFields: ['*']     });  // Warbler 2  var flWarbler2 = new ArcGISDynamicMapServiceLayer("https://fwisweb1.gov/arcgis/rest/services/Warbler_Map/Warbler_Map_Readonly/MapServer/1", {          mode: FeatureLayer.MODE_ONDEMAND,          outFields: ['*']     });  app.map.addLayer(flWarbler0);  app.map.addLayer(flWarbler1);
TimWitt
Jay,
we would need to see the whole code. But from what I can see here, you need to use the var names in your add expression.
app.map.addLayer(flWarbler2);  app.map.addLayer(flWarbler1);
That might fix it, but again I would need to see all of the code.
Tim
TimWitt
Jay,
Tim
KenBuja
MVP Esteemed Contributor
Your syntax doesn't make sense if you're trying to add these as FeatureLayers. Unless the argument ArcGISDynamicMapServiceLayer is mapped to "esri/layers/FeatureLayer" in your require statement, shouldn't it be
var flWarbler1 = new FeatureLayer("https://fwisweb1.gov/arcgis/rest/services/Warbler_Map/Warbler_Map_Readonly/MapServer/0", {
         outFields: ['*']
jaykapalczynski
Honored Contributor
Tim Witt & Ken Buja
Thanks....it was a mixture of issues...I had the code below to start with but as Tim pointed out the addLayer was not pointing to the correct Var....
GOOD TO GO.....appreciated thanks
 // Warbler 0
 var flWarbler0 = new FeatureLayer("https://fwisweb1.gov/arcgis/rest/services/Warbler_Map/Warbler_Map/MapServer/0", {
         outFields: ['*']
 // Warbler 1
 var flWarbler1 = new FeatureLayer("https://fwisweb1.gov/arcgis/rest/services/Warbler_Map/Warbler_Map/MapServer/1", {
         outFields: ['*']
