Trouble Getting setExtent to work
7012
10
05-01-2015 07:56 AM
SteveSmith1
I am trying to set my map extent to the last place it was located when a user comes back to the page.  When I use setExtent, the page comes up blank without showing the map at all.  I think it may have to do with the spatialReference, but I am not sure.  Any help would be appreciated.
require([
        "dojo/dom-construct",
        "esri/Color",
        "esri/dijit/Geocoder",
        "esri/dijit/Popup",
        "esri/InfoTemplate",
        "esri/layers/ArcGISDynamicMapServiceLayer",
        "esri/map",
        "esri/symbols/SimpleFillSymbol",
        "esri/symbols/SimpleLineSymbol", "dojo/domReady!",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane"
        ], function (
        domConstruct, Color, Geocoder, Popup, InfoTemplate,
        ArcGISDynamicMapServiceLayer, Map, SimpleFillSymbol, SimpleLineSymbol
            try {
                var sls = new SimpleLineSymbol("solid", new Color("#444444"), 3);
                var sfs = new SimpleFillSymbol("solid", sls, new Color([68, 68, 68, 0.25]));
                var popup = new Popup({
                    fillSymbol: sfs,
                    lineSymbol: null,
                    markerSymbol: null
                }, domConstruct.create("div"));
                map = new Map("ui-esri-map", {
                    basemap: "streets",
                    center: [-76.347304, 39.533987], // long, lat
                    zoom: 11,
                    sliderStyle: "small"
                pathArray = location.href.split('/');
                protocol = pathArray[0];
                host = pathArray[2];
                var appFolder = '<%=PavementManagement.Properties.Settings.Default.appFolder %>';
                url = protocol + '//' + host;
                var _pavementInfoTemplate = new InfoTemplate();
                _pavementInfoTemplate.setTitle("<b>Road Condition Information</b>");
                _pavementInfoTemplate.setContent("Road Name: ${NAME} <br> Type: ${SURFDESC} <br> From Street: ${FROMSTREET} <br> To Street: ${TOSTREET} <br> Assessed: ${RoadAssessed} <br><a href='" + url + appFolder.replace("none", "") +  "/Assessment/AssessmentEntry.aspx?id=${OBJECTID_1}'>Update Road Assessment</a>");
            var pavementLayerURL = "http://gismaps.harfordcountymd.gov/arcgis/rest/services/ICT/PavementManagement/MapServer";
            var pavementLayerOptions = {
                "id": "pavementlineLayer",
                "opacity": .5,
                "showAttribution": false
            var pavementLayer = new ArcGISDynamicMapServiceLayer(pavementLayerURL, pavementLayerOptions);
            pavementLayer.setDisableClientCaching(true);
            pavementLayer.setInfoTemplates({
                0: { infoTemplate: _pavementInfoTemplate }
            pavementLayer.setVisibleLayers([0, 1, 2]);
            map.addLayer(pavementLayer);
             updateExtent(map, pavementLayer);
            dojo.connect(map, "onExtentChange", showExtent);
            geocoder = new Geocoder({
                arcgisGeocoder: {
                    url: "http://gismaps.harfordcountymd.gov/arcgis/rest/services/ICT/OriginalGeoFencesAddress/GeocodeServer",
                    placeholder: "Enter Address (No Suffix)",
                    autonavigate: "True"
                map: map
            }, "ui-esri-dijit-geocoder");
            geocoder.startup();
            catch (err) {
                alert('error: ' + err);
function updateExtent(map, pavementLayer) {
        try{
            var Xmin = getCookie('Xmin');
            var Ymin = getCookie('Ymin');
            var Xmax = getCookie('Xmax');
            var Ymax = getCookie('Ymax');
            if (typeof Xmin !== 'undefined') {
                var startExtent = new esri.geometry.Extent();
                startExtent.xmin = parseFloat(Xmin);
                startExtent.ymin = parseFloat(Ymin);
                startExtent.xmax = parseFloat(Xmax);
                startExtent.ymax = parseFloat(Ymax);
                startExtent.spatialReference = pavementLayer.spatialReference;
                map.setExtent(startExtent);
        catch (err) {
SteveSmith1
I had tried switching over to "on" earlier, I keep getting errors though.  The page was built on an earlier example I had that was still using the 3.10 script.  I am a little rusty on the js side and the mapping stuff is all new to me.
switching to dojo.connect(map, "onLayerAddResult", updateExtent(map, pavementLayer)); seams to have made it worse.  Now my layer loads, but the basemap does not...
