Track editors and edits using JS API 3.9
16292
17
06-20-2014 08:08 AM
AlexGole1
Hi all,
I am trying to get started on building a web app that would allow our users to verify who, what, and when a layer was last edited last.
I am wondering if any of you have tips, examples, or other to get me started?
Below is a picture of (roughly) what I intend to create.
Thank you,
Alex
[ATTACH=CONFIG]34774[/ATTACH]
AlexGole1
Archiving maintains the history of the geometry and all the fields.  Since editor tracking just records information in fields, the history is maintained as well.  Take a look at the screen shots below.  You can see the 'Last Edited User' and 'Last Edited Date' fields are different values.  This will show what was edited, who edited the feature, and when the feature was edited.
[ATTACH=CONFIG]34848[/ATTACH][ATTACH=CONFIG]34849[/ATTACH]
How do you access the archived data? A simple identify is enough to show me who edited the feature last? Is "queriable"? When I enable archiving the table I have stay the same, i do not have 'Last Edited User' and 'Last Edited Date' fields. It is only when I turn on track edits that they are added.
Thank you for time and sorry I am completely newbie on archiving/tracking data.
Alex
JakeSkinner
Esri Esteemed Contributor
You will want to enable editor tracking, and then enable archiving.  Once archiving is enabled, add the archive class to ArcMap following the steps in this link:
http://resources.arcgis.com/en/help/main/10.2/index.html#//003n000000rr000000
The archive class will store all of the edit history.  You will want to publish this as a service, and then access this service in your application.
AlexGole1
Thank you! I think the only thing I dont see now is the "user" you showed on your screen shot. I have the time and everything but not user.
Alex
JakeSkinner
Is the user showing as blank?  Try making some edits to the feature class and see if the user becomes populated.  Also, be sure you are showing the 'last_edited_user' field and not the 'created_user' field.
AlexGole1
My bad I was only looking at the "created_user".
It all works!
Thank you,
Alex
AlexGole1
One thing I notice is that when I want to publish the Archive class "Acres Archive" ArcGIS Server does not accept it because it is not registered layer. Is it possible to register an archive class then?
DarkoRadiceski
Hi Alex,
Were you able to get this resolved?
DaveBarrett
been looking at this problem today and have found that if you want to publish the archive class you can create a view to the class in the database connection eg SELECT * FROM name_H
when adding to ArcMap you need to use the archive OID as the unique identifier. This will then publish To arcgis server.
Hope this helps
Dave
