Token required. what does this mean?
7170
06-17-2015 12:03 AM
RuthUmbach
There was an error trying to process this table. Token required.
What does this mean? And where do I get this Token?
YousefQuran
Hi Ruth Umbach,
Token is a key like Username & Password to allow accessing ArcGIS Server. You need to Generate a Token and pass it with your requests from server.
check it here, and if you can tell us which API you are using so we can help you more.
If you find the Answer, please check it as Correct Answer from Actions (below) in order to improve our community.
Regards,
Yusuf
