TOC/Legend Widget and sub layer popups
3987
10
11-15-2013 08:04 AM
PatKeegan
The wicked awesome TOC/Legend Widget allows users to change visibility of sub layers, but it does not control the popup on sub layers. This means a sub layer can be turned off but that sub layer's popup will still appear on a map click.
Any advice on how to use this tool to also control sub layer popup visibility?
This is the widget i am referring to:
https://wheaton.maps.arcgis.com/home/item.html?id=9b6280a6bfb0430f8d1ebc969276b109#
Much thanks!
EricRussell1
Could you post your final work?  I am trying to do almost exactly the same thing. Thanks!
